![]() | Home > Technical > Nas step and trailer electrics |
Yep thats right, I bought a cheapo bracket that fits behind the tow bar on standard cars and modified it to fit repainted waxoyled and it's pretty neat, there is probably a better/proper fit but i couldn't be arsed to find it/pay for it/invent it......delete as necessary. I'll take a picture tomorrow
![]() 110 HCPU Tipper |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
With the NAS step doesnt the socket go in the hole in the cross member??
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 ![]() ![]() ![]() |
Thats almost wha i did - the paint bit. At least thats how it should be which is what i wanted to check
If that were true the problem is the loom doesnt fit through and you would have to drill the mounting holes Mike |
Loom does fit
TallPaul Member Since: 28 Aug 2007 Location: Nr Reading Posts: 270 ![]() ![]() |
This thread needs pictures
![]() XS 110 Utility maybe one day..... (did they fix the quality yet?) |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 ![]() ![]() |
What ken said...ive just pulled mine through taught at the moment before how i work out how to mount securely You cannot teach stupid people to do clever things
The plug on mine definately didnt fit - it went through the square hole but not the round one at the back - no way the plastic lugs either side both prevented it Mike
Take the round plug apart
It was too well sealed to ruin it by doing that...and then drill the cross member to put the bolts through and introduce corrosion?! Mike |
The round socket tis easy self tappers and sealant will be fine
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
I don't have a NAS bumper but the loom should easily fit through the hole in the crossmember.
![]() ![]() Click image to enlarge One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
beetroot Member Since: 15 Dec 2008 Location: manchester Posts: 41 ![]() |
nas step and tow plug in cross member, no problem
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
So you all dismantled the socket end and fed the wires in?
Dont get me wrong i like it in there but didnt want to dismantle it and introduce corrosion in the crossmember by drilling it and ingress into the connection! Mike |
The bumper surely doesn't change things
![]() If it still leaves the standard hole then you should be able to feed the socket through (takes a bit of a wiggle to work out the right angle ![]() I drilled the cross member and used rivnuts to secure the socket. You don't have a lot of room so make sure you get it right the first time. I didn't paint the exposed metal in the cut ![]() ![]() ![]() + New Defender 110 First Edition |
