Home > Puma (Tdci) > leaking crankshaftseals?
theflyingscotchman
Austria 2012 Defender 110 Puma 2.2 DCPU Tamar Blue
Hi!
A couple of months ago the engine startet to leak oil. The garage diagnosed faulty crankshaft seals.
Both seals rear + front including front cover were replaced. To no, or very little effect.
After the last repair the rear seal startet to leak again after about 150 km. The car is now back to the garage again. According to the mechanic the problem is that they can not locate the leak within the engine. Apparently it is not the crankseal. Frontcover is still leaking but less then before. Right now the engine is taken apart and the Garage is trying to locate the problem. The engine is now on itīs third rear and second front crankseal. Unfortunately it looks like neither the garage nor LR-Austria seem to have any idea whats wrong.
My question is if there are any known probelms (which might result in leaking engine oil) with the 2.2 tdci engine.
It is a MY 2012 Defender with only about 13000 km on the clock. Fortunately itīs still under warranty.
Any help would be appreciated!
Post #310527 22nd Feb 2014 10:37am
theflyingscotchman
Need help from engine pros!
After 4 nearly 4 weeks car is back from the garage. Just a short summary of the latest work done one the engine.
Again a new front cover and crankshaftseals. New sump and gaskets. As well as new seals for the Ladder frame - connection between oil pan and clutch housing. According to the garage the ladder frame gasktes werenīt fitted correctly- new gastkets were fitted unfortunately to very little effect. After about 300 km the b****y thing started to leak again - not as bad as it used to, be - but still ... it leaks.
Has anyone had a similar situation? Any ideas?
Post #318450 23rd Mar 2014 7:03pm
shaggydog
My rear crankshaft seal leaks.
As the clutch is nearly due changing I'm just treating it as a constant oil change till the clutch needs doing as its worth doing while in the area.
Just keep topping it up, if you start loosing a lot quickly then its pursuing but to my mind 3 drips 7 hours is really not worth worrying about.
If it does really bother you clean it all off with some brake cleaner or gunk to have a really clean engine and then go for a drive till engine is warm then come home and inspect everywhere from top of your engine downwards and try and pinpoint the area it is coming from,
Also take your engine breathers off and clean them out. My cyclone breather got blocked and caused the block to pressurise making it leak past a gasket on the side of the block. cleaned the breathers, changed the breathers back to a clean dry engine.
My 2 cents.
Post #318458 23rd Mar 2014 7:18pm
MK
A not straight crankshaft (or the end of it) Puma 110" SW
Post #318528 23rd Mar 2014 9:09pm
Dieselhead
Demand a new engine as its not right Big Cry Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #318793 24th Mar 2014 7:48pm
