Home > Td5 > TD5 Low fuel cause pump squelch / whine |
thanks for the update. Let us know what happens
19th Mar 2014 11:35am |
Little Tom Member Since: 20 Aug 2013 Location: Lancashire Posts: 134 |
Cheers Razler, I'm currently looking into buying a new guel filter housing part at the moment so hopefully that will sort it. Michael was just telling me a story about a friend of his who slept with a land rover, lonely nights in the desert..
20th Mar 2014 9:25am |
Razler Member Since: 16 Nov 2013 Location: NORTHUMBERLAND Posts: 50 |
I'd buy britpart fuel filter assembly but change bleed valve for genuine..
20th Mar 2014 1:13pm |
I have actually god an LR bleed valve already, I bought one for my existing fuel filter head but it would fit, I seem to have some off fuel filter head, all the brass fittings going into it are different to the pics I have seen. I've given up trying to understand why its like that or where its come from, just gonna replace it and see how it goes.
Good shout on the britpart item though. Still just need to understand which part number I need..... Michael was just telling me a story about a friend of his who slept with a land rover, lonely nights in the desert.. |
20th Mar 2014 2:30pm |
david mitchell Member Since: 01 Jul 2012 Location: Meath Posts: 418 |
My independent says you should not let your fuel run to low before filling up, as running the tank low puts stress on the pump! Any thoughts? Td5
5th Aug 2014 1:11pm |
aus10RRW Member Since: 19 Oct 2013 Location: Aberdeenshire Posts: 20 |
The fuel pump on my girlfriends TD5 90 was whining for months and really noisy, it lasted 6 months before it died altogether. If the noise is coming from your pump then maybe its a sign that the pump is on its last legs?!
17th Aug 2014 2:10pm |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 789 |
Did you ever resolve this issue?
I have the same and am pulling my hair out trying to chase it about!? Chris |
30th Jul 2015 6:45pm |
