![]() | Home > Td5 > TD5 Low fuel cause pump squelch / whine |
You should let the glow plug go out anyway.
Little Tom Member Since: 20 Aug 2013 Location: Lancashire Posts: 134 ![]() ![]() ![]() |
Yes very true, which is another reason I've not really been pushing for answers, I'm quite happy to let it go through the process of warming up before starting. Even so, it still is a lot of squelching from the pump. Michael was just telling me a story about a friend of his who slept with a land rover, lonely nights in the desert..
Did you do the fuel purge after fitting washers seals etc?
It was a while back now, I did the press the acceleration pedal 5 times trick if thats what you mean? Michael was just telling me a story about a friend of his who slept with a land rover, lonely nights in the desert..
Yep that's the purge. Did you fit genuine seals and washers to the injectors as I've heard of non gen ones failing quite quickly
Yes all genuine parts. It actually ran smoother after doing the seals and O-rings. I never get the fuel down as low as the Orange as I think it would struggle more and eventually not start, although I have never put that into practice. Michael was just telling me a story about a friend of his who slept with a land rover, lonely nights in the desert..
Are there any leaks from the FPR?
There may be.... The reason I say this is I saw the usual signs, bellhousing with oily residue and oily puddle on floor so I bought replacement Vigo O-rings and gasket. On closer inspection this weekend I noticed the rocker gasket was leaking at the back where that half moon shape is, so I fixed that and gave it all a clean. I'm going to run it for a couple of days and check the fpr again as the oil leak muddied the waters so to speak. Michael was just telling me a story about a friend of his who slept with a land rover, lonely nights in the desert..
If it is the FPR that is leaking would that acount for the noise? I didnt think air could get in through the FPR only fuel out? Michael was just telling me a story about a friend of his who slept with a land rover, lonely nights in the desert..
If their is enough gap for fuel to get out, there's enough gap for air to get in
Makes sense, I will check it out this weekend and repair it if needed. Thanks for your help, mk1
No problem, considering our vehicles are twins it seems logical for me to carry out the same repairs
Hi Mk1,
I managed to get the time to give the FPR new seals and new gasket last night, as ever the job took longer than expected with me trying to get the actual pressure regulator out to fit the big O ring. ANyways, still quite a bit of whining / purging from the fuel pump. My next port of call is the fuel filter and I have decided to go with a new filter head as the one I have got is just causing me confusion. I previously bought a new air bleed valve but after checking the head on mine the connection looked different, front and rear connections. Anyways, thats by the by, just thought I'd give an update. ![]() Tom Michael was just telling me a story about a friend of his who slept with a land rover, lonely nights in the desert.. |
