Home > Maintenance & Modifications > Rust prevention or treatment
Page 2 of 3 <123>
ericvv
Joe the Plumber wrote:
Everyone here says use Dinitrol (at least no one suggested Waxoyl), but I assume none of them have read the July 2013 report by Dr Phil Green from the University of Hertfordshire School of Engineering and Technology called "Assessment of Wax Coatings Using a Salt Spray Cyclic Corrosion Test".
In this, six well known corrosion protection products were each put, at the same film thickness, onto three identical bare steel plates, along with one steel plate left bare, and subjected to wet salt spray testing in a controlled environment. After the time was up, the products were cleaned off and the amount of corrosion assessed.
The results, after 2084 hours of testing in a ridiculously harsh environment, put Dinitrol 3125HS in 4th place, with Bilt Hamber's Dynax S50 a comprehensive 1st. There was the barest trace of rust on the very edges of the plates coated with it, whereas the Dinitrol had around 75-80% corrosion under it. Waxoyl was 98-100% rust incidentally.
The test was done at the request of Bilt Hamber, but I can find no hint of any bias towards them in the report. It's all backed up with multiple photographs of the results.
It's your vehicle, and your money, but if you want the best corrosion protection you can get for it, Bilt Hamber is the firm to use, and they're British too:
www.bilthamber.com
If you contact them, they will probably let you have a copy of the report. It's a real eye opener.
It's easy to do it yourself with their big high pressure aerosol cans as they come with 2' tubes with diffusers on the ends to get into all the awkward areas. Peter Hamber suggested to me to use Dynax S50 inside the 110's box sections, and Dynax UB on the exposed surfaces. I'm going to use the UC to protect the less exposed mechanical assemblies too.
Having previously tried various alternatives, I've used BH stuff on my vehicles for eight years now, and wouldn't entertain anything else. And no, I'm just a customer, not an employee (although I ought to be on commission!)
I hope this is of interest.
Joe, surely of interest. Surprised this was never brought up before. But if there is such a comparative test done, with Bilthamber coming out tops, why don't Bilthamer put an easy link to this report on their website? Cannot imagine any better advertising than that, no?
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #316123 15th Mar 2014 8:27am
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
Thanks Eric. I'm not quite sure why BH don't use it in their advertising. Peter Hamber seemed quite happy to forward me the full 42 page report, so I'm puzzled that it isn't on their website.
I'm pleased to report that, although I've asked them to confirm they mean for the current models, Lokari tell me they are making the tooling to produce aluminium inner fenders with rubberised edges for the rear wheel arches and that they will be available "in May".
If they're as good as my previous Opel Manta liners (although they were plastic), and they advertise them correctly, I'm certain they'll sell hundreds of sets.
Post #316199 15th Mar 2014 5:03pm
df1
Sounds good, both the treatment and liners.
Post #316205 15th Mar 2014 5:37pm
Matthew_Mills
ericvv wrote:
Matthew_Mills wrote:
So I'm assuming that Dinitrol is an oil wax mix that you spray on, having cleaned everything down... I've seen a couple of threads on how to do so I guess go read gain is the answer...
Matthew, I don't think Dinitrol is an "oil wax" as you call it there, contrary to something like waxoyl often used in the UK. Dinitrol does not have a petroleum product smell like the above.
Now as to Dinitrol application, a lot is to say for leaving this messy job to a professional, but then not just to the first one around the corner. It took me months of searching here in Switzerland, and finally I drove the truck from here all the way to Belgium to get it done by a garage who still are interested to do this job, and who follow the rules by the book.
Dinitrol still today are providing to their professional applicators for specific car models a constantly updated step by step handbook of the entire process to follow for that car model, which Dinitrol product to use on what, how to apply it, which elements to take off of the car, how and what to protect before starting, etc....
A good Dinitrol center will follow these rules by the book, and also have the equipment needed to properly apply the product into all nooks and crannies... For instance, the inside of my chassis legs was sprayed with pure Dinitrol at a pressure of 80bar.... I don't think you can do this at home.
When my car was treated, it was first half taken apart by them, wheels and door cards removed, lights taken off, wheel arch brows removed, ceertain trim removed, all door screws taken out one by one for extra access, etc. etc. And all put back professionally without any damage.
Now, if you find an outfit which still can/want to do that in the UK, I recommend to go there. If not, better to do yourself.
Frankly, at the time, I had to go as far as Antwerp to find someone who was still passionate about this, when you talk with people like that, you immediately will feel that they know what they talk about. More recently, we finally found one outfit here in Switzerland who are even better than the one in Antwerp, not here in Geneva where they charge you the world, but do not really know any more the art of doing this. It is a body/engineering firm at the other end of the country near Basel, where a friend of mine had his new Defender done a year ago, and they are just amazing. Mine will go there this spring for a full retreatment now after first treatment 3 years ago.
Sofar I have not seen anybody in the UK here on this forum talk as highly and confidently about a Dinitrol provider their end, so guess the kind of people we found in Antwerp and here are becoming like needles in a haystack.
All above to say that a real professional can probably still do a very superior job at workable prices. When I have seen how much work they put into it, I thought even the price they charge here in Switzerland is more than worth it.
Good luck, Eric
Bow down Bow down great response... I love this forum, so many people with passion for what we all love - our Defenders... I'll think long and hard about your comments... I love Switzerland so might just make an excuse and come down... Maybe we can say 'hi' too... Thanks again...
Post #316265 15th Mar 2014 8:58pm
Matthew_Mills
As an additional thought, I'm in the process of enquiring whether Lokari make wheel arch liners for the later Defenders. They do them for models to 1989:
http://www.lokari.de/epages/62716287.sf/en...-0879-0880
And it may be these will also fit the newer ones. I had a front pair from them for my old Opel Manta which were astonishingly good.
Keeping the cack out of the nooks and crannies in the first place must be a very good idea.
I'll report back once I know more.
Joe the Plumber... great contribution and I will be contacting them too... Bow down you star...
Post #316266 15th Mar 2014 9:02pm
Matthew_Mills
Thanks all let's keep the debate going... Whatever. I do and I'm decided I will prevent... Pictures, costs and process will be fully documented.
You're all great and this typifies why I love to be part of the defender force... There is NO replacement! But let's not start another thread on that comment!
Post #316268 15th Mar 2014 9:05pm
ericvv
Here are some details of the Swiss Dinitrol specialist which my forum friend "kitoper" found and where he had his "Hunter" treated.
http://www.defender2.net/forum/topic19961....p;start=30
And details for the Antwerp specialist where mine was initially treated.
http://www.defender2.net/forum/topic13479....l+belgians
Anyone we can help with anything for this, or who need more info, please shout. Thumbs Up
Post #316285 15th Mar 2014 10:15pm
RockJaw
United States 2013 Defender 110 Puma 2.2 SW Santorini Black
Eric
Good question.
Proof of the pudding is in the eating though, and we have found a special place for both Dinitrol as well as Dynax.
Each has their special purpose though, and application. The Dinitrol range includes a product in their "4000" range whose specific product number I forget, but it is a fairly thick substance with zinc powder and it is absolutely perfect for aggressively corrosive environments. This is a personal favourite of mine and i am always with at least one or two cans of this product in my workshop.
The previous poster was kind enough to mention the Dynax range though, and we try to spray all our recovery vehicles with the Dynax products as early as possible. Dynax has been remarkably successful for us. having said that we also do apply the 4000 Dinitrol product over the Dynax in some areas like the wheel arches and front of the firewall where we expect to see more aggressive medium gather on our Landies.
The external and painted areas are done in Dynax, especially along welds and folds, but the gaps are filled with the thicker zinc impregnated Dinitrol 4000 product.
By the way, the Dinitrol 4000 range also does well as a fairly decent sound damper for road noise, especially around the rear wheel arches.
Great post!! ****CENSORED****
Post #321835 6th Apr 2014 3:46am
110SEB
I think really you can happily leave it until the car is 2 years old, then a good steam clen and a thorough waxing treatment which should be repeated every few years. 5 year intervals?
Post #321847 6th Apr 2014 8:10am
jimbob7
/\/\ The advantage of doing it from new is the chassis is as clean as it will ever be and requires a hell of a lot less jet washing before hand,but providing you check for damage and keep the underside clean with a regular jetwash waitin a couple of year won't harm. Pov.spec,ftw. 2006, 110,TD5.
Post #321860 6th Apr 2014 9:29am
Cakey
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
I suppose the test was with a salt solution which most of us do not suffer from . Hence don't buy a car from the seaside .
Excellent report though , bilt has always been a super product .
Not sure many of the waxy / dini guys use dynax .
Mine have all been dinitrol / waxoyl acf50 not seem any rust yet
Post #321862 6th Apr 2014 9:36am
fixit
www.bilthamber.com
Hi Joe i have just read there web site and quite a few other sites and this stuff looks to have quite a following.
Can you remember how many cans you used on yours as you can order from the web site and i would like to avoid more than one shipping charge
Thanks
Post #321868 6th Apr 2014 9:51am
dgardel
Italy
Just checked my Defender after 5 years (I waxoyled it on 2009). No sign of rust!!!!! Neither under the wax coat on the welding points.
I used the original Waxoyl (I love the smell) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #321923 6th Apr 2014 3:07pm
Joe the Plumber
I've probably gone over the top with mine but so far on the chassis and underside I've used six cans of S50, four of UC and I've got four of UB still to use.
And I've not done inside the doors, bonnet or bulkhead yet!
Realistically, I reckon ten cans, used more sensibly than I have, would be ample for the whole job.
Post #322077 7th Apr 2014 7:42am
Arranvet
Don't forget the ACF-50 for door and bonnet hinges et. as advised by Zag
Post #322104 7th Apr 2014 12:37pm
Page 2 of 3 <123>
