![]() | Home > Maintenance & Modifications > Rust prevention or treatment |
Matthew_Mills Member Since: 16 Feb 2014 Location: Somerset Posts: 152 ![]() ![]() |
Had cause to remove a rear wheel today... Got my head under the arch, blimey what a load of mud despite a wash at the weekend, need to do a better job.
Reaching out for quotes now... Dinitrol seems the get the most votes but i will check out others too. One question, what about using a jet wash post treatment, is the 'stuff' good enough to resist the pressure? Or is it back to a hose? |
micomlab Member Since: 10 Aug 2021 Location: quebec Posts: 1 ![]() ![]() |
Great!!! Thanks for this valuable post. |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1822 ![]() ![]() ![]() |
As an update I did my 2007 110 station wagon in 2010 shortly after I bought it. It was ex Spain so apart from mud and dust there was very little corrosion at all.
Working on my drive I jet washed it several times and left it to dry for a week (in the uk summer) I then did all box sections with Rustbuster MIL spec cavity wax and all external areas in Dinitrol black wax. Have only fairly randomly jet washed it underneath in the last 200,000km and 11 years. Have just completed a bit of tlc this time with the benefit of a barn and ramp, straightened the rear panels and checked underneath. Apart from a tiny bit of surface corrosion on the rear crossmember between the rail and crossmember and for some reason again slight surface rust on the body crossmember under the rear seat, there is no corrosion at all. All now re treated and ready for the next 11 years! Used the same products again as I still had unused sealed cans..... |
Does anyone do a clear/transparent rust proofing product?
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2147 ![]() ![]() |
Bilt hamber dynax uc https://bilthamber.com/product/dynax-uc/ |
M.J.Persius Member Since: 03 Apr 2021 Location: Ayrshire Posts: 17 ![]() ![]() ![]() |
https://www.arc-rite.co.uk/corroless-cci-4...zontalTab1 Haven't used this product in particular but have previously used corroless stuff and in my experience it is very good. |
