Home > Puma (Tdci) > Puma EGR blanking plate FREE :-)
Did this plate make any difference to your cars running.
Made no difference
20%
 20%  [2]
Made my car better and i will post the results
80%
 80%  [8]
Made my car worse and i will post the results
0%
 0%  [0]
Total Votes: 10
Page 12 of 12 <123 ... 101112
Caterham
It beggars belief
The money that's been thrown at this car it would have been cheaper for them to give me a new one from the outset Big Cry
(and that's it ignoring the money I've chucked at it!)
The turbo has without a doubt improved things - Saturday I was whizzing round into big numbers (3500rpm) gear after gear no trouble just like I knew it could should.
Then back to square one (knocking type noise like excess injector sound and a feeling like the brakes are on / a real lack of pick up) - intermittent though....not talking a few seconds but for a whole journey or just a bit of it or none of it???????
Please help.....i want this sorted before my license expires in 2050!
I know this sounds like my usual old dribble and that's all you've got to go but from my perspective i've to numerous dealers etc and they all say it's ok / as it should be and some fails....be it a gearbox, ecu, propshaft, heat shield mounting or transfer box shaft... Big Cry or turbo Big Cry hand brake
Post #313589 4th Mar 2014 9:08pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
let me have it for a week.....do a REAL WORLD TEST on it ...you can borrow Derek the 90.... Putting Dreams on Drives at JLR Solihull..
Post #313739 5th Mar 2014 2:01pm
Caterham
Shocked
gulp....tthh tthank you fff for the vv very kind offer but she likes to be handled gentley...
Very Happy two things. once again thanks for the lift home.....(hopefully Ian has passed on my gratitude?).
I must apologise for not replying to Ian note but (and back onto topic Very Happy ) I've got a simple blanking plate (no hole in it) which I want to in install as I hope this will once and for all confirm one way or the other whether my egr is leaking or not?
so watch this space.
Post #313743 5th Mar 2014 2:12pm
Caterham
Evil or Very Mad gggrrrrrhhhh! Big Cry
I can not believe it.
Spent too long today trying to get egr off with 10mm spect etc....top bolt easy peesie.
Lower bolt tried and tried all sorts of sockets and adapters but eventually realised I was wasting my time. The hose next to this bolt has a clip on it which due to its angle of rotation it's in the way of me ever getting a socket on. No bother I'll try an open ended spanner......eventually I realise the spanner is a duff and must have been manufactured wrong as the opposite faces of the spanner aren't parallel......so onto the 3/8"......got the second bolt off Very Happy. Done it....just need to slide the egr blank in next to the egr gasket (simple).....
Bl**dy gasket is the wrong size Big Cry
Thud
Post #314756 9th Mar 2014 6:18pm
K9F
Caterham wrote:
: I can not believe it. Thud
Ideally this is what you need not a single blank with no hole......and with a little added ingenuity you could even add a tab on the edge like the first blank and then slip the blanks in and out in a few minutes.
Caterham knowing your luck the whole thing will end in tears.
Big Cry :blub:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  If you go through life with your head in the sand....all people will see is an ar5e!!
Post #314800 9th Mar 2014 7:34pm
Caterham
Big Cry
It's going that way......I'll be riding to work tomorrow......
Bought one blank.....lost it (or throw it away) bought another then found the original in with my after shave!!!
So they are both too small Crying or Very sad
(unless they fit the output side of the egr....but the moment I can't see how you access that bit??)
Post #314811 9th Mar 2014 7:54pm
Bergos
Portugal 2007 Defender 110 Puma 2.4 HT Keswick Green
Red Desert wrote:
there will be an EGR KILLER KIT at the end of the year ......from a small company (doing porsche race cars) in germany......with the control light on the dash off
So? What happened to this project? Is this or similar kit available? Bergos
LR Defender 110 HT 2007 (2.4 Puma)
https://www.facebook.com/LR.Wanderlust/
Post #711279 7th Jun 2018 5:30pm
