Home > Technical > TD5 'Groans' in Reverse until warm
danridge
United Kingdom 2004 Defender 90 Td5 XS CSW Java Black
Truck is cold. I select reverse and start moving backwards. It makes a disturbing 'groaning' noise until I select 1st and start to move off. Doesn't exhibit same issue once warm.
I think the rear half shaft/s need replacing given the harsh clunk if not very gentle with the clutch. Could this be related?
Thanks, Dan.
Post #313136 3rd Mar 2014 3:55pm
munch90
maybe handbrake shoes binding a bit
Post #313150 3rd Mar 2014 5:05pm
bga86
2015 Defender 90 Puma 2.2 HT Fuji White
Spigot bush Thumbs Up
Post #313168 3rd Mar 2014 6:03pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
yea most likely spigot bush most td5s suffer at some stage.
Gearbox out to change it...but wouldn't bother unless you plan to change the clutch and Dmf.
N
Post #313189 3rd Mar 2014 6:58pm
munch90
why would spigot bearing only make a noise in reverse
I know spigot bearings do make noise but this wouldn't this be forward and reverse ?
Post #313191 3rd Mar 2014 7:03pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
Mine does it in reverse too - and yes it's the spigot bush.
In my case it's because when I'm reversing, it's usually slowly and I'm slipping the clutch.
As Nidge says, it's a gearbox-out job to change it. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #313199 3rd Mar 2014 7:15pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
engine out.............quicker. Putting Dreams on Drives at JLR Solihull..
Post #313218 3rd Mar 2014 8:19pm
danridge
Thanks guys - what'll happen if I just leave it? best case/worst case (untill I have a job that needs the engine or gearbox out)
Post #313401 4th Mar 2014 11:41am
bga86
Really? Can do them in about 5 hours by taking transfer box off then gearbox out.
It'll get worse but won't harm the car, have a few customers who have had this noise for years!
Post #313505 4th Mar 2014 6:47pm
danridge
Thanks bga86
Dont s'pose anyone has done a 'how to guide'? (big ask I'm guessing)
Post #313536 4th Mar 2014 7:50pm
bga86
Not that I know of but next time I've got one to do at work I'll knock something up. Not a job I would even contemplate doing without a ramp and gearbox stand to be honest.
Post #313539 4th Mar 2014 7:58pm
danridge
Post #313540 4th Mar 2014 7:59pm
bga86
That's the one
Post #313593 4th Mar 2014 9:18pm
danridge
OK thanks - I'll make sure I do it when the clutch gives up or a similar 'opportunity' presents itself Thumbs Up
Post #313760 5th Mar 2014 3:56pm
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
@Dan... is it practical to reverse out in low box??
Better low speed control and so little/no need to slip the clutch and potentially create the groan... Just a thought Smile Jon - 110 td5 [sold]. Currently Defenderless.
Post #313761 5th Mar 2014 4:09pm
