Home > Technical > TD5 'Groans' in Reverse until warm |
maybe handbrake shoes binding a bit
3rd Mar 2014 5:05pm |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 |
Spigot bush
3rd Mar 2014 6:03pm |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 818 |
yea most likely spigot bush most td5s suffer at some stage.
Gearbox out to change it...but wouldn't bother unless you plan to change the clutch and Dmf. N |
3rd Mar 2014 6:58pm |
why would spigot bearing only make a noise in reverse
I know spigot bearings do make noise but this wouldn't this be forward and reverse ? |
3rd Mar 2014 7:03pm |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 |
Mine does it in reverse too - and yes it's the spigot bush.
In my case it's because when I'm reversing, it's usually slowly and I'm slipping the clutch. As Nidge says, it's a gearbox-out job to change it. Dave Green Goddess - 1998 Defender 110 300tdi |
3rd Mar 2014 7:15pm |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1384 |
engine out.............quicker. Putting Dreams on Drives at JLR Solihull..
3rd Mar 2014 8:19pm |
danridge Member Since: 28 May 2013 Location: Bath Posts: 438 |
Thanks guys - what'll happen if I just leave it? best case/worst case (untill I have a job that needs the engine or gearbox out)
4th Mar 2014 11:41am |
Really? Can do them in about 5 hours by taking transfer box off then gearbox out. It'll get worse but won't harm the car, have a few customers who have had this noise for years! |
4th Mar 2014 6:47pm |
Thanks bga86
Dont s'pose anyone has done a 'how to guide'? (big ask I'm guessing) |
4th Mar 2014 7:50pm |
Not that I know of but next time I've got one to do at work I'll knock something up. Not a job I would even contemplate doing without a ramp and gearbox stand to be honest.
4th Mar 2014 7:58pm |
This the job? http://www.youtube.com/watch?v=qAqeS3I79bI
4th Mar 2014 7:59pm |
That's the one
4th Mar 2014 9:18pm |
OK thanks - I'll make sure I do it when the clutch gives up or a similar 'opportunity' presents itself
5th Mar 2014 3:56pm |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 |
@Dan... is it practical to reverse out in low box??
Better low speed control and so little/no need to slip the clutch and potentially create the groan... Just a thought Jon - 110 td5 [sold]. Currently Defenderless. |
5th Mar 2014 4:09pm |
