Home > Technical > Car ramp - specification |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Chaps,
I'm going to get a couple of car ramps to make working under the Defender a bit easier. Most of the ones I can find are rated to 1000kg each (2k per pair). Given the vehicle doesn't weigh more than 4t, that shouldn't be a problem. Have any of you had any experience of these / would recommend a particular set? I found some on Difflock.com rated to 1t each for £70 (see here) and some on machine mart rated to 1.25t each for £35 (see here). The machine mart ones are narrower (250mm cf 340mm) but the difflock ones aren't rated as high. Thoughts One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
1st May 2010 11:51am |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
If you are feeling flush a set of'Raptor ramps' would be the ideal solution . Otherwise I tend to just use 1 ton ramps and they work ok.
http://www.raptor-engineering.co.uk/about-...ction-ramp Glyn |
1st May 2010 11:59am |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
Those Rapture ramps are great. Adding to list to stuff I can't afford
1st May 2010 9:06pm |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
I bought the Machine Mart ones. Cheaper Nd work fine. Solid and strong and wide enough
1st May 2010 9:09pm |
Thanks all.
The Raptor ones look the dog's danglies but at £190 I might pass (read: "spend the difference on more kit"). Machine Mart suggest that they have wider ones available. If so, I'll get them. 240mm is wide enough right now (whilst I have 235 tyres) but won't be once I move up to 265. I'd rather have a bit of room to play with than be balancing on the ramps whilst I work underneath. I'll not worry too much about the weight, then. 1t per wheel should be plenty. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
1st May 2010 9:16pm |
