![]() | Home > Technical > Car ramp - specification |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Chaps,
I'm going to get a couple of car ramps to make working under the Defender a bit easier. Most of the ones I can find are rated to 1000kg each (2k per pair). Given the vehicle doesn't weigh more than 4t, that shouldn't be a problem. Have any of you had any experience of these / would recommend a particular set? I found some on Difflock.com rated to 1t each for �70 (see here) and some on machine mart rated to 1.25t each for �35 (see here). The machine mart ones are narrower (250mm cf 340mm) but the difflock ones aren't rated as high. Thoughts ![]() + New Defender 110 First Edition |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
If you are feeling flush a set of'Raptor ramps' would be the ideal solution
![]() http://www.raptor-engineering.co.uk/about-...ction-ramp Glyn ![]() |
Those Rapture ramps are great. Adding to list to stuff I can't afford
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
I bought the Machine Mart ones. Cheaper Nd work fine. Solid and strong and wide enough
Thanks all.
The Raptor ones look the dog's danglies but at �190 I might pass (read: "spend the difference on more kit" ![]() Machine Mart suggest that they have wider ones available. If so, I'll get them. 240mm is wide enough right now (whilst I have 235 tyres) but won't be once I move up to 265. I'd rather have a bit of room to play with than be balancing on the ramps whilst I work underneath. I'll not worry too much about the weight, then. 1t per wheel should be plenty. ![]() + New Defender 110 First Edition |
