Home > Puma (Tdci) > 2.2 XS, Can you switch off the Traction Control?
Page 3 of 5 <12345>
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I have been on an Off-Road driving course in the Neath Valley, in my Puma, and the instructor got me driving slowly up a steep gravel slope with alternate patches of fine and medium gravel such that, without centre diff lock on TC was activated on both axles and eventually all wheels were braked and engine stalled. Oh, I was in low 1st. We just stopped. No foot brake. Just put on Hand brake. Then clutch in, select low reverse, clutch out, handbrake off and start engine. NO feet on pedals and slowly reverse back. Of course ALL safety procedures were undertaken, looking around and sounding horn etc: before moving back..
2nd try was in low 2nd and faster speed with CD lock on. No problem. TC did activate on 1 wheel but we just powered through.
My point was that when the engine stalled the vehicle just stopped without application of brakes because TC had locked all wheels. The handbrake was applied so that clutch could be operated to change gear. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #311556 25th Feb 2014 6:42pm
That makes perfect sense and is what you'd expect to happen, however it is very unlikely that it was TC holding you on the brakes once the engine stalled, it would have been the fact it was in gear with a stalled engine which held it. In this respect a non-TC vehicle would be held in the same way.
It is interesting and not entirely expected that the TC can actually stall the vehicle, since TC works by braking a wheel which is rotating faster than the others. At, or near, a stall, all wheels will be stopped so the TC cannot detect slippage (in a similar way it is theoretically possible for ABS to be unable to detect that all four wheels are locked if they lock at precisely the same instant).
Incidentally (and not wishing to pick nits) the clutch is out when the pedal is pressed and in when the pedal is released.
Post #311574 25th Feb 2014 7:56pm
WelshGas
Your probably correct Blackwolf, the vehicle was probably held by the stalled engine, but as the instructor explained, 1 wheel on each axle started spinning, TC then braked that wheel which transferred power to the non-spinning wheel which because of the track surface started to spin/lose traction thus operating TC on that side. All 4 wheels now braked and hence engine stall, so at that point with the brake system pressurised one could argue either way that the engine or wheel brakes are holding the vehicle, at that point.
I will take note of your comments regarding the clutch, I should have said " clutch pedal in/out ". Thumbs Up LANDYWATCH
Post #311579 25th Feb 2014 8:17pm
JWL
The traction control will have nothing to do with holding the stalled vehicle on a hill, when you do it by the book and stall you are being held by the stopped engine and the fact it is in gear, the brakes have nothing to do with it. I too have done the same as described above on LRE days with both a 2.4 and a 2.2, the latter was a year ago as my son pointed out tonight.
One thing that must be remembered is that my encounter with problems is on a 2002 Td5, as has been mentioned earlier things have improved and a new system is in use on newer Defenders.
Defenders of my era were new to tc and many people have had bad experiences of the older system and it is not rated highly by some but as long as you are aware of its limitations it is helpfull. Technology has moved on and tc is much improved on later models.
Post #311607 25th Feb 2014 9:11pm
jst
TC does not lock out user input but for those unused to the feel of a different brake pedal it could appear that way on reflection.
the use of the handbrake on a failed hill climb i find interesting. so with WG experience hand brake on is only holding one wheel via the prop with no CDL.
LRE teaching is leave the handbrake out the procedure. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #311654 25th Feb 2014 9:59pm
WelshGas
Sorry, but I disagree regarding handbrake. If the handbrake cannot hold the vehicle, how does a stalled engine? Also, how do you change from forward to reverse gear without the vehicle rolling back if not held by the handbrake in some fashion? Because if you do not use handbrake or foot brake once you disconnect the engine from the drive train then what is to stop the vehicle rolling back, and you have to disconnect to engage reverse. Exclamation LANDYWATCH
Post #311667 25th Feb 2014 10:24pm
I would have thought that without centre diff lock on tc could only have been active on either axle separately rather than simultaneously?
Post #311669 25th Feb 2014 10:26pm
JWL
The tc works by reversing the abs, i.e. on abs if a wheel locks under braking then it will release the brake on that wheel whereas on tc if a wheel is spinning excessively it will apply the brake to that wheel irrespective of CDL or not. Just think of Discovery II's, many didn't have CDL
Post #311676 25th Feb 2014 10:32pm
isn't that just an issue for them since the intro of the electronic version on other models means it is useless offroad getting covered in mud and jamming on/not auto releasing Whistle
Easily ignored with auto gearbox models when you have a separate park brake.
Post #311678 25th Feb 2014 10:32pm
munch90
doesn't the tc pulse brake on spinning wheel to send drive to other wheel . if it locked wheel that was spinning to send drive to other wheel that would mean the wheel trying to drive has to drag a locked wheel ?
Post #311683 25th Feb 2014 10:40pm
munch90
it doesn't just release brake it pulses the brake other wise you would be pulled to the side that has brakes
Post #311684 25th Feb 2014 10:43pm
jst
correct, its cross axle on defender but works on all 4, neither Bosch or Siemens takes account of the CDL position. you could have two fronts doing 30mph with TC acting on one of them with the rears stationary (no CDL ) Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #311688 25th Feb 2014 10:46pm
jst
Kenny, you use the footbrake as that holds all 4 wheels irrespective of CDL. i didnt say you don't use the footbrake.
you only hold the vehicle on a stalled engine for the second (ish) after you release the footbrake prior to turning the key with the clutch already up in reverse. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #311690 25th Feb 2014 10:49pm
jst
no, its always been that way in my experience.
we dont have an issue with EPB jamming up on vehicles that use them (the EPB) regularly with the excpetion of vehicles that wade alot. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #311692 25th Feb 2014 10:50pm
jst
TC can stall the vehicle as your experience above shows, but once wheels on the same axle are both braked to 0mph simultaneously TC will take the brakes off so you are not left with all 2 (or 4 for that matter) wheels braked on - in a stall for example. But i agree that the TC can brake all 4 wheels sufficiently enough to create the stall.
which ties in with the comment above about learning to live with TC and adapt driving style.
i do agree there are times when TC is better off being switch off too! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #311695 25th Feb 2014 10:55pm
Page 3 of 5 <12345>
