Home > Technical > Noisy idle,Posb Clutch?
General Lee
2008 Defender 110 Puma 2.4 SW Bonatti Grey
Hi all,I have recently noticed that after driving for a couple km,lets say 40,my Puma idles very rough and cranky when stationary and in neutral.BUT, as soon as i depress the clutch she is back to normal....Is this a clutch on its way out? Big Cry
Post #309521 19th Feb 2014 2:34pm
General Lee
Sorry...that should be engage the clutch...... Embarassed
Post #309523 19th Feb 2014 2:35pm
110 John
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Orkney Grey
Could be the thrust bearing goosed
Post #309600 19th Feb 2014 6:55pm
General Lee
Im seeing mention of the clutch release bearing in other posts? Thrust bearing is inside the engine?............ Big Cry
Post #309794 20th Feb 2014 5:48am
110 John
Its in the bell housing if it is that it rattles untill you press the clutch pedal
Post #309812 20th Feb 2014 7:53am
Porny
Site Sponsor
What year is your Defender... there has been a few clutch 'updates'? IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #309887 20th Feb 2014 11:26am
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
Mine is currently in for that exact same issue!
They have had it 4 days now and are still trying to diagnose. As soon as i have confirmation of what it is then I will let you know.
They have checked quite a lot and are currently rummaging around in my transmission.
Is a much more pronounced sound in cold weather ===================================
Steve
90 xs sw in Stonoway Grey - Sold
110 USW X-TECH
Post #309894 20th Feb 2014 12:11pm
Lishlandy
On the back of this post I called up for an update and they need to keep it again overnight, and were quite frank that the transmission is in pieces and being rebuilt, possibly over the weekend. This is where the knocking is coming from but have not highlighted a particular part as yet.
Hope this helps and saves you the hassle that they are going through isolating the issue, but doesn't look like it's good news. Mine is a 2012 defender so luckily in warranty ===================================
Steve
110 USW X-TECH
Post #309898 20th Feb 2014 12:21pm
General Lee
tHATS NOT GOOD NEWS......I was hoping it would just be a bearing.Mine is a 2008 Model.But lets see what the stealers tell you.Holding thumbs!
Post #309931 20th Feb 2014 2:06pm
General Lee
@ 110John- The manual locates the thrust bearing on the cam rocker inside the engine and the PILOT BEARING INSIDE THE FLYWHEEL.Is this maby the bearing you are talking about?
Post #309932 20th Feb 2014 2:10pm
TJ101
If its a good rattle, and goes when the clutch is depressed, ie clutch disengaged,
I have just had the same on my 2008 lanner 90,, Clutch plate centre hub springs rattling/missing,,
As Porney says,, numerious "clutch updates" Shocked California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #309935 20th Feb 2014 2:23pm
