Home > My Defender > What Did You Do In Your Defender Today |
Mine came off during an off roading episode
8th Feb 2014 8:02pm |
Is there any point in putting it back on or buying a new one?
8th Feb 2014 11:07pm |
Mine's gone three years without, makes the servicing a little easier. The one downside is, mainly because it needs replacing, the serpentine belt squeals when we've been through deeper puddles. I must put the new one on I bought a couple of years ago, I may do if we have a dry day.
8th Feb 2014 11:17pm |
I don't suppose you know the part number do you? That's if yours is a td5. I could only find the number for a puma one.
Sorry just re-read your post and I think you meant a replacement belt n under tray |
8th Feb 2014 11:32pm |
I guess it's down to individual interpretation but the MOT requirements are "Check that there is a registration plate at both the front and the rear of the vehicle, and check each one for security and condition." but if it is not "likely to be misread or is not easily legible by a person standing approximately 20 metres to the front/rear of the vehicle" then you could query any failure due to it being in the front windscreen. |
9th Feb 2014 12:07pm |
@Mk1, I just left the under tray off, it had snapped just in front of the gearbox cross member, I could put a plate on it to re-instate it but as I don't drive through much brush I've just left it off. I will get round to replacing the fan, power steering, alternator belt one day. If you need the part number for that I'll dig it out. You should be able to get the plastic sump guard off Dgardels links to the Russian Rave download.
9th Feb 2014 2:18pm |
9th Feb 2014 2:52pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5741 |
Click image to enlarge Covered new rear shelf. Also installed new rear speaker mounts and the sub |
9th Feb 2014 5:55pm |
Sold the sankey , but it went to a very good home
Revised the roof-rack table fixings on the new hannibal roof rack |
9th Feb 2014 6:08pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2760 |
double din facia fitted and parrot asteroid smart installed! full write up in the In Car Electronics section
Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
9th Feb 2014 7:11pm |
dwilliams851 Member Since: 22 Sep 2013 Location: Santiago Posts: 36 |
Changed brake pads on the Defender, the local dealer here in Chile wanted the equivalent of 500 quid to do it, so ordered the bits from the UK and did it myself. Removed the spacers put on by the previous owner (made the car look a bit tacky)
Got my old Disco up and running (after 6 months) and found this under it Click image to enlarge Didn't move even after getting the car started. |
9th Feb 2014 7:16pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5864 |
Friday. Td5 passed the MOT. 4 advisories:
1. Slight play in NSF wheel bearing 2. Slight play in OSR wheel bearing 3. Play in wiper linkages (despite changing spindle boxes, and spiral cable.) 4. Play in rear seat backs. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
9th Feb 2014 7:25pm |
Phatcat Member Since: 01 Nov 2013 Location: W yorks Posts: 98 |
Click image to enlarge Had the old girl round Tong at Bradford today. A really good day. |
9th Feb 2014 9:23pm |
EddieB Member Since: 08 Apr 2013 Location: Durham Posts: 57 |
Fitted my new lightforce 170's
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
11th Feb 2014 5:35pm |
