Home > Technical > Webasto Help
Page 2 of 2 <12
NorTD5
Norway 2000 Defender 110 Td5 CSW Rioja Red
So far as I know it was fitted by the importer - I have a pretty good file of old records and cannot find any suggestion it was fitted later.
However, I did talk to a local mechanic friend (not a Land Rover enthusiast, nor a Webasto expert) who thought that all Webasto heaters were just to come on with the engine, so perhaps it was set up like that. Seems unlikely though as it is definitely switching on and switching the heater fan on from the timer unit in the cab. I have read through the Webasto thread on here, http://www.defender2.net/forum/topic14809.html and it seems like a low cost fix that is worth a try before I put in a new pump that I may not need, although it also occured to me that I should try reversing the car into its parking space so the webasto is on the ower side and seeing what happens then! That will have to wait until the huge pile of snow that fills half the drive at the moment has melted, though!
Cheers,
Mark
Post #305989 7th Feb 2014 7:35pm
Cold_n_Wet
Norway
just to make sure we are speaking about the correct heater.
The circulation pump is the big black lump - sorry if its obivious, but several years experience has taught me to some good lessons .
Check with the guys on the Norwegian Land forum, there may well be some one local with the webasto diagnostic kit, who could test the pump with the thermotest software.
It sounds to me the pump has gone, but remote diagnostics is a hard thing to do.
you can open the top panel, remove the pump wires and apply 12v to the pump and hear if it circulates.
Glen "Rafiki" 2007 110 STW - Rolling rebuild.
Post #306014 7th Feb 2014 8:51pm
NorTD5
That's the one! Thanks Glen - I have been working on other things (wacky electrical gremlins) today so have not looked at it again, but have the name of someone in the local off road club from a colleague. I am going to call him to see if he knows of a decent local auto electrician, so will add the Webasto diagnostics to that list.
Cheers,
Mark
Post #306334 8th Feb 2014 8:25pm
Page 2 of 2 <12
