![]() | Home > Puma (Tdci) > 2008 Puma paint bubbleing. |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1728 ![]() ![]() |
Always worth a try
Worst they can say is no! Mines away at the moment having some paint done. Cheers Tom ![]() |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
unless your car was registered in january 08 then it will still be less than 6 years old? Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
jeeves Member Since: 10 Jul 2011 Location: lancashire Posts: 91 ![]() ![]() |
My 2008 110 had similar and it is covered
CARMARK2014 Member Since: 28 Dec 2013 Location: SHEFFIELD Posts: 57 ![]() ![]() ![]() |
This is what i thought if the paintwork/corrosion warranty is 6yrs they should do it. Defender 110
yep, I've had a number of bits done - if one dealer rejects then you could always try another but I'm sure they will Cheers, David
I have had a looked in the warranty book and it says as long as the defender has been cleaned to comply with land rover and has had the body work inspected by the dealer every year. This is were they can refuse as the last service was done at an independant specialist and there for wasnt inspected. I can but take it to then and see. Defender 110
Is it the same as the link below (my post)? If so you may need to broker a deal....
![]() http://www.defender2.net/forum/topic23030.html?highlight=brokered If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 9th Feb 2014 6:29pm. Edited 1 time in total |
Its rusting in the same palce as the one in the link, but i think they will have there excuses but whether its checked ever year is a load of rubbish its just started bubbleing and checking it last year wouldnt make any differance. Defender 110
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 ![]() ![]() |
Hello,
Could I just clarify something, i understand having the body inspection carried out by the lr dealer would keep the body warranty covered so to speak which i don't have a problem with. As i myself understood after the first three years of main dealer servicing / vat registered garage. The main sections of the warranty will have ran out. The vehicle servicing could be carried out by the owner, which most of us seem to do, and this would not affect the body warranty side of things am i right in my thinking or have i miss understood |
As i read the warranty book it say the bodywork should be checked and signed buy the lr dealer upon anual free inspection. This is how they will get out of repairing my landy as i didnt take it for inspection last year. Defender 110
You can service it yourself but must take it to the lr dealer for a free corrosion inspection to keep it in warranty.. Defender 110
In a bit of contradiction to that my 2011 which is having the approved work done at the moment, has never been back to land rover, as the last owner serviced it at his firms workshop from new and they were fine with it at my local dealership? so it might not be refused if you have only missed a couple.
Cheers Tom Defender puma dormobile camper |
Thanks for that i will mention that if they refuse. I guess it will be down to the dealership. Defender 110
Cuthbert Member Since: 26 Oct 2013 Location: Up North Posts: 1535 ![]() |
Remember the basic fitness for purpose element of consumer legislation.
