Home > In Car Electronics > Totally amped......well not anymore |
Cakey Member Since: 19 Feb 2013 Location: Cheshire Posts: 468 |
Does it Display amp error ? On pioneer
Also have you got power to jbl Check speaker connections . I assume you checked both fuses , I think 2 on back of amp Last edited by Cakey on 30th Jan 2014 8:48pm. Edited 1 time in total |
30th Jan 2014 8:39pm |
DingoDad Member Since: 02 Jan 2014 Location: Norwich Posts: 20 |
Nope. Nothing looks different on the head unit 94 Defender 110 Wagon
2012 Mini Countryman SD (Work Car) |
30th Jan 2014 8:41pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20263 |
What exactly isn't sounding just right? The HU powered speakers or the Amped speakers?
30th Jan 2014 8:45pm |
Front speaker are fine. Very volume out of rear. Just found a section in user guide (not in the setup section) for configuring the rear output. Will try it out when I get home. 94 Defender 110 Wagon
30th Jan 2014 8:50pm |
So it's the Amp, I'm interested to know why the fuse has blown in the first place.
There obviously is an over load occurred for it to blow which is quite a major thing really. What is the RMS wattage for the Amp and rear speaker?. Those figures should more or less match. The load on the Amp can be an issue too which depends on how the speakers are wired up. Hopefully the Amp hasn't been blown along with the fuse. |
30th Jan 2014 9:00pm |
Found the setting - and whammo - WE ARE BACK! 94 Defender 110 Wagon
31st Jan 2014 10:09am |
What was it? Amp power on?
31st Jan 2014 11:27am |
when first turned on the head unit has an admin function ( Initial settings) and I needed to set to rear/rear. This changes the output to the RCA inputs on the amp.
Feel like a real dummy now! 94 Defender 110 Wagon 2012 Mini Countryman SD (Work Car) |
31st Jan 2014 11:33am |
No one is fool proof! Could be worth the OH could have sorted it for you, now that would be embarassing!
31st Jan 2014 11:40am |
Click image to enlarge Click image to enlarge Click image to enlarge never admit defeat in front of the O/H. Heres a few pics of the setup. I would have like to have mounted the 6x9's in the upper rear but I couldnt find any speaker boxes. I had the existing ones so went with them. It still sounds decent enough 94 Defender 110 Wagon 2012 Mini Countryman SD (Work Car) |
31st Jan 2014 1:26pm |
Looks pretty good. See if you can get the Amp mounting board carpeted though.
If you go on Ebay you can get small bits for a few pennies rather than rolls. |
31st Jan 2014 4:07pm |
was also thinking of getting some clear perpex mounted on some spacers - wasnt sure if it would overheat. Still leaves the sides exposed but protects it a little? 94 Defender 110 Wagon
31st Jan 2014 4:58pm |
I wouldn't seal it in unless you've got ventilation fans which is a hell of a lot of work.
If you want some protection I'd buy some Alu strip from Wickes and make a custom made bent to shape guard. Just two or three strips over and around it leaving a1/2" gap between the strips and Amp would go nicely. If you really wanted it pretty once you've got the bends and shapes correct you could get it anodised, power coated or painted. Do you see what I'm trying to suggest, then work lamp protector but instead of a cage like design just strips of alu. Like this Click image to enlarge But slightly different bug you get the idea, a bit like how my sub grille works. |
31st Jan 2014 5:19pm |
