Home > In Car Electronics > Totally amped......well not anymore
DingoDad
England 1994 Defender 110 300 Tdi SW Blenheim Silver
Hi
Recently had the following system fitted to my 110. Pioneer DAB head unit (6600) , pioneer speakers (10cm up front and 6x9 in the rear hooked up to a jbl amp (GT5-A40). All sounded lovely and then the fuse blew. When I replace it I don't get any real volume from the rear speakers.
There's a little sound (ie) low volume but I don't know what do to get back to normal
. . Is there some sort of setup / config I have to do? Can't see anything in the head unit menu.
Btw I didn't install the system and am a bit of a novice. 94 Defender 110 Wagon
2012 Mini Countryman SD (Work Car)
Post #303555 30th Jan 2014 8:29pm
Cakey
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
Does it Display amp error ? On pioneer
Also have you got power to jbl
Check speaker connections .
I assume you checked both fuses , I think 2 on back of amp
Post #303559 30th Jan 2014 8:39pm
DingoDad
Nope. Nothing looks different on the head unit 94 Defender 110 Wagon
Post #303564 30th Jan 2014 8:41pm
What exactly isn't sounding just right? The HU powered speakers or the Amped speakers? TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #303566 30th Jan 2014 8:45pm
DingoDad
Front speaker are fine. Very volume out of rear. Just found a section in user guide (not in the setup section) for configuring the rear output. Will try it out when I get home. 94 Defender 110 Wagon
Post #303571 30th Jan 2014 8:50pm
So it's the Amp, I'm interested to know why the fuse has blown in the first place.
There obviously is an over load occurred for it to blow which is quite a major thing really.
What is the RMS wattage for the Amp and rear speaker?. Those figures should more or less match.
The load on the Amp can be an issue too which depends on how the speakers are wired up.
Hopefully the Amp hasn't been blown along with the fuse. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #303577 30th Jan 2014 9:00pm
DingoDad
Found the setting - and whammo - WE ARE BACK! 94 Defender 110 Wagon
Post #303685 31st Jan 2014 10:09am
What was it? Amp power on? TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #303705 31st Jan 2014 11:27am
DingoDad
when first turned on the head unit has an admin function ( Initial settings) and I needed to set to rear/rear. This changes the output to the RCA inputs on the amp.
Feel like a real dummy now! Big Cry 94 Defender 110 Wagon
Post #303708 31st Jan 2014 11:33am
No one is fool proof! Laughing Could be worth the OH could have sorted it for you, now that would be embarassing! Rolling with laughter TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #303709 31st Jan 2014 11:40am
DingoDad
never admit defeat in front of the O/H.
Heres a few pics of the setup.
I would have like to have mounted the 6x9's in the upper rear but I couldnt find any speaker boxes. I had the existing ones so went with them. It still sounds decent enough 94 Defender 110 Wagon
Post #303739 31st Jan 2014 1:26pm
Looks pretty good. Thumbs Up See if you can get the Amp mounting board carpeted though.
If you go on Ebay you can get small bits for a few pennies rather than rolls. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #303783 31st Jan 2014 4:07pm
DingoDad
was also thinking of getting some clear perpex mounted on some spacers - wasnt sure if it would overheat. Still leaves the sides exposed but protects it a little? 94 Defender 110 Wagon
Post #303812 31st Jan 2014 4:58pm
I wouldn't seal it in unless you've got ventilation fans which is a hell of a lot of work.
If you want some protection I'd buy some Alu strip from Wickes and make a custom made bent to shape guard.
Just two or three strips over and around it leaving a1/2" gap between the strips and Amp would go nicely.
If you really wanted it pretty once you've got the bends and shapes correct you could get it anodised, power coated or painted.
Do you see what I'm trying to suggest, then work lamp protector but instead of a cage like design just strips of alu.
Like this
But slightly different bug you get the idea, a bit like how my sub grille works. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #303825 31st Jan 2014 5:19pm
