Home > Technical > Creaking by pedal box 2013 puma 90
Page 2 of 2 <12
keith
I told you exactly wot it is . 100% mate . Gota replace a silly wee bolt wi a bigger one at the exact point you are talking about .. Get em to rock it side to side HARD whilst the monkey lies underneath and goes " ah ! There's the Censored there Thumbs Up
Post #303240 29th Jan 2014 8:51pm
MVS
United Kingdom 2012 Defender 110 Puma 2.2 USW Bonatti Grey
keith wrote:
http://www.defender2.net/forum/topic22229.html
I posted this as the exact same symptoms in the exact same plece i had
Impossible to find by yourself and it drove me crazy for weeks .dealer had it 3 different times even changing both sides bushes on everything but to no avail .
Fiinaly they found it ..... One person underneath looking whilst 2 on top either side rocking it side to side .
There is a one inch 10mm standard LR bolt in the location of drivers floor - gearbox tunnel . Its well hidden and the wrong bolt for the job , far to small and was bent like a banana when they got it out . Simply replaced with a more adequite bigger heavier bolt . Thumbs Up
Sorry to resurrect an old thread but mines started doing this & i wondered if you had a picture of the area where this bolt is.
I've looked at everything else. Mine starts doing it on a drive of longer than 30miles or so, so i thought it was the hockey stick bush under the drivers floor bu it aint Sad
To add;
Is it the one that goes through the floor directly below the hand brake mechanism in the back left corner of drivers footwell to bolt the body to a chassis bracket??
Post #450358 29th Aug 2015 4:03pm
LR90XS2011
Id be interested to know which bolt as well, as mine is still creaking!! DEFENDER 90 TDCI XS,
Post #450400 29th Aug 2015 6:53pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
Mines too, but just got very used to it, don't really notice it now.
Post #450409 29th Aug 2015 7:18pm
Samblers
Australia 2010 Defender 110 Puma 2.4 SW Fuji White
Guys, see my comprehensive post (with pictures) on how i solved my year-long battle with the creaking/notchy puma clutch pedal
http://www.aulro.com/afvb/90-110-130-defen...ost2313715
Cheers, Sam
Post #450470 30th Aug 2015 5:05am
LR90XS2011
thanks Shamblers
unfortunately mine isn't clutch related it does it during steering and suspension movement or when braking / accelerating and can be felt through the floor, I think its body/chassis fixing related rather than steering or suspension and tightening a load off loose bolts in the floor area has reduced it, my Mrs recons that from the passenger seat the noise is behind the dash but from the drivers seat it feels like its in the floor. I did have the clutch spring squeak issue but some spray grease sorted that. DEFENDER 90 TDCI XS,
Post #450497 30th Aug 2015 7:29am
MVS
Here's pictures of the culprit on mine;
Under carpet below hand brake
Side on underneath. Actually loose & captive washer pulling through chassis bracket
Directly from below
Replaced with bigger bolt/washer/Nylock
Post #450566 30th Aug 2015 11:13am
Caterham
so what exactly is being bolted to the chassis with that bolt cos my initial interpretation was that the floor plate was bolted to the chassis but it clearly isn't. the floor plate is cut around the bolt?
Post #501321 6th Feb 2016 4:22pm
Retroanaconda
The seat box.
Post #501373 6th Feb 2016 6:31pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Mine was the coils in the clutch pedal spring rubbing together. A dash of 75w90 fully synthetic gear oil and quiet as a mouse for nearly two years. (Gear oil because it does not dry out) 1953 80"
1987 mini city e
2011 90"
Post #501811 7th Feb 2016 7:20pm
Caterham
This is going to sound like i'd moan even if I won the lottery.....but....
I've had issues since day one, some have come and gone but the clutch related problems have never completely gone away.
Something (clutch pedal, transmission mount, clutch?) felt like it broke, moved into alignment and now no problem changing ie it doesn't feel like the clutch is dragging when changing as you can blip th engine revs, vibrations in gearbox are gone?
I should and am happy but what the hell is it as I have a feeling it ain't going to last?
Post #504126 12th Feb 2016 9:51pm
Curtis-Bay
Thanks - this has been driving me mad
I have had exactly the same symptoms for a couple of months and diagnosis was virtually impossible because the problem only began after about 30 miles - probably when the floor area around the handbrake began to get warm. I tried pedal lubrication, seat runners, handbrake and floor panels but to no avail.
I lifted the floor mats and located the bolt mentioned by Keith and it was loose. I tightened it up and the corresponding one on the passenger side and BINGO! - no more creak.
You are a genius.
Post #557235 19th Aug 2016 2:01pm
justinp
My clutch is feeling a little creaky / rough at the top of the travel, I checked the bolt beneath the handbrake, and sure enough it was very loose, so I've tightened it up.
Sadly the creaky feel is still there, so I'll take a look at the other suggestions for the cause.
Post #557669 21st Aug 2016 12:35pm
Page 2 of 2 <12
