Home > Technical > Creaking by pedal box 2013 puma 90
madrunner
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Santorini Black
Evening all
Need to pick your brains.
Wife's 90xs has started making a creaking noise from the floor area around the pedal box when operating the clutch .
Any ideas ?
If its a quick fix ill sort it if not back to the stealers.
Thanks in advance of your cleverness !!!!
Cheers Bow down
Post #298781 14th Jan 2014 6:55pm
SimonDavies
Wales 2010 Defender 90 Puma 2.4 HT Zambezi Silver
http://defender90xs.blogspot.co.uk/2013/12...n.html?m=1
Posted up on here by a member a few months ago (I'm sorry I can't remember who and sorry for stealing your thunder)
It may be of use to you.
Post #298832 14th Jan 2014 8:16pm
madrunner
Cheers Si Thumbs Up
I'll take a peak at that first
Post #298835 14th Jan 2014 8:23pm
theorangebandit
Get a can of WD40 and squirt it up ib the cavity at top of the pedals. I squirt all mine monthly. Aim for the springs thats what squeeks. Its a land rover quirk youll grow to love
Post #298836 14th Jan 2014 8:30pm
madrunner
Cheers TOB - I'm going to get it indoors at work and get squirting !!!!!
Post #298860 14th Jan 2014 8:59pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Just remember to put some newspaper/cardboard on the floor under the pedals esp. if you're spraying from above.
After silicone spray, Mr Sheen and lithium grease, half a tin of 3 in 1 may have fixed it on mine.
Looks like some awful chemistry experiment under there now. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #298933 14th Jan 2014 10:57pm
ericvv
Post #298959 15th Jan 2014 4:53am
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
SimonDavies wrote:
http://defender90xs.blogspot.co.uk/2013/12/clutch-pedal-lubrication.html?m=1
No problem at all - thanks for reposting? Thumbs Up http://defender90xs.blogspot.co.uk/
Post #298963 15th Jan 2014 7:04am
x-isle
I had a similar problem, creaky clutch pedal.
Then something weird happened. Coming down a slip road to a roundabout, put my foot on the clutch, depressed, changed gear took foot off pedal.
Pedal stayed down.
Thought it was a knackered master cylinder. Turned out the pedal was just stuck. A dose of WD40 and I've not had the problem since and no creak either and that was 2 years ago. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #298980 15th Jan 2014 8:49am
madrunner
Right chaps, had a crawl around the truck in daylight today and the creaking is definitely not clutch pedal related.
It's coming through the floor pan/tunnel area right by the clutch pedal.
Something ain't tight somewhere by the sound of it.
We've booked it into the stealers a week Monday to let them sort it out.
Strange one !! Question
Post #299666 17th Jan 2014 4:47pm
Dieselhead
Get your wife to help with that job then Laughing Thumbs Up Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #299709 17th Jan 2014 6:52pm
madrunner
Lol lol quality Bow down
Post #299716 17th Jan 2014 7:08pm
keith
http://www.defender2.net/forum/topic22229.html
I posted this as the exact same symptoms in the exact same plece i had
Impossible to find by yourself and it drove me crazy for weeks .dealer had it 3 different times even changing both sides bushes on everything but to no avail .
Fiinaly they found it ..... One person underneath looking whilst 2 on top either side rocking it side to side .
There is a one inch 10mm standard LR bolt in the location of drivers floor - gearbox tunnel . Its well hidden and the wrong bolt for the job , far to small and was bent like a banana when they got it out . Simply replaced with a more adequite bigger heavier bolt . Thumbs Up
Post #299718 17th Jan 2014 7:17pm
Samblers
Australia 2010 Defender 110 Puma 2.4 SW Fuji White
Mine had the bushes, and then the pedal box replaced by the dealers (under warranty) to fix same issue. Didnt fix... 2 more visits later and it was fixed. They didnt tell me what they replaced/lubed but there was lots of swearing.
Seems like a common issue. 4 months on and still good.
Post #303109 29th Jan 2014 1:39pm
madrunner
Well its deffo not the pedal box, crawled all over it and it's coming from the tunnel, floor bulkhead area.
Went into the dealers last week, apparently tightened some bolts, stopped the creaking for 15 miles now it's back just as bad.
It's going back in for a couple of days to get to the bottom of what's what.
Post #303231 29th Jan 2014 8:38pm
