Home > Puma (Tdci) > Help - Ignition key
richardg
2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Help - Ignition key
The ignition key on my Puma has been sort of stiff over the past of couple of days - the key turns fine until it hits Position II, then it was a bit tricky to turn, and some times tricky to turn off.A bit if jiggling and it was working. Of course the inevitable has now happened and the key wont turn at all beyond position I. Big Cry I don't think it's a problem with the levers /leaves in the barrel as key turns to position I okay and the steering lock works fine on and off. Any ideas ?
Post #302662 27th Jan 2014 7:01pm
landys1
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Santorini Black
Squirt of WD40 worth a shot... 1959 Series 2 Ragtop
1989 SWB Stationwagon
1998 300Tdi Hard Top and 2012 2.2 Puma Hardtop (at work)
2011 Puma 90 2.4 XS
Post #302667 27th Jan 2014 7:14pm
richardg
Thanks, tried this (bit more than a squirt - shoved loads in !).
Post #302671 27th Jan 2014 7:21pm
JWL
Have you another key you can try? I've had this happen, admitedly on slightly older motors, and has come down to the key being worn. On my 2002 110, it had been playing up as you describe and nearly didn't turn to position 2. I had a new key cut by a normal key cutting shop in town and all was fine.
Post #302711 27th Jan 2014 8:35pm
richardg
Gave up trying to fix this morning - local independent Landrover dealers came out and hot wired the vehicle to get it going. Fortunately they are a business run by common sense rather than accountants (apologies to all accountants out there) so they had a complete lock set and barrel sat on the shelves, all fixed by this afternoon. I've seen reference to a technical service bulletin LTB441 on this problem, any-one know about this as I might try Landrover for a goodwill payment as the vehicle is less than a month out of warranty ?
Post #302907 28th Jan 2014 6:10pm
Tribord
France 2011 Defender 110 Puma 2.4 XS DCPU Zermatt Silver
Instead of WD40 you should try graphite powder.
Post #302941 28th Jan 2014 7:49pm
Cuthbert
Listen, learn and take a tip from Tribord ............ WD40 for locks? ... ARGH!
This is the stuff to use http://www.amazon.co.uk/C-K-T6283A-Graphit...dry+powder
It also works a treat on all sorts of other doorlocks, padlocks etc.
Post #303025 28th Jan 2014 10:52pm
Cuthbert
....... and your key will slide in and out and turn like a hot knife through butter. A very light dusting goes a very long way and you might well marvel at just how smoothly your locks will operate in all conditions.
Post #303026 28th Jan 2014 10:55pm
Blacktt600
England 2008 Defender 110 Puma 2.4 XS CSW Cairns Blue
Graphite was always recommended for the Stanley Yankee screw drivers of old! A soft pencil rubbed on the key works just as good.
Post #303031 28th Jan 2014 11:30pm
MartinK
I would give ACF50 a go - I have used it on locks a few times, and it's worked a treat Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #303070 29th Jan 2014 9:42am
Cuthbert
Whilst ACF50 has a myriad of useful applications - it doesn't seem to be a standard feature in a locksmith's toolbox. Personally I'll stick to the dry graphite powder.
Post #303178 29th Jan 2014 6:07pm
richardg
Thanks for the advice, will try graphite on the new lock. The old one had fallen to bits inside - WD40, ACF50, Graphite or pixy dust wouldn't have fixed it !
Post #303188 29th Jan 2014 6:36pm
