Home > Puma (Tdci) > No drive on puma 2.2 110 |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5729 |
Have you tried putting it into diff lock?
Are any of the shafts spinning underneath whilst in drive? How does clutch pedal feel? Andy |
27th Jan 2014 4:13am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17452 |
If locking the centre diff restores drive then suspect halfshaft or diff in either axle. If locking the centre diff makes no difference then suspect the adaptor shaft between main and transfer box, a common problem with Puma Defenders.
Use the search facility to look for "loss of drive" for several other threads on this problem. |
27th Jan 2014 7:54am |
ronwong Member Since: 28 Jun 2012 Location: Singapore Posts: 120 |
locking centre diff does not work, from searching, it seems to be the shaft between the transfer case and the gearbox....
27th Jan 2014 8:24am |
Not sure if your vehicle is under warranty or not, but if not, don't despair, this isn;t as big and difficult repair as it at first appears.
The parts cost approx £120 in the UK. Fitting involves removing the transfer box (not the main gearbox) and is actually easier and quicker than you might think. |
27th Jan 2014 4:48pm |
dudley472 Member Since: 15 Nov 2012 Location: wolverhampton Posts: 96 |
3rd Sep 2019 10:57am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3645 |
several threads on here, fit ashcroft for a permanent solution DEFENDER 90 TDCI XS,
3rd Sep 2019 6:58pm |
This thread is over five years old so he's probably fixed it by now. Darren
3rd Sep 2019 8:29pm |
