Home > Technical > Just checking about MAF |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20335 |
Have you recently had any EGR issues or simply you suspect the MAF? ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
25th Jan 2014 8:36pm |
Egr is removed and as many of the problems people have on here seem to relate to the MAF I thought I'd try unplugging it to see if there was a difference. I should have put that my defender is a 2004 td5.
25th Jan 2014 8:43pm |
I think you can clean it with electrical contact cleaner.
It could indeed cause a varied range of issues as it monitors air volume into the intake and various other things electronically so if it is fouled up it could put it's readings out altering performance. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
25th Jan 2014 11:08pm |
I took it out and cleaned it last week so I don't think that's the problem. I'll see if my multi meter works tomorrow to see if it gives me any ideas. If it shows up nothing I'll see if the mileage is back to normal with the MAF unplugged.
25th Jan 2014 11:25pm |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 |
Sounds like maf troubles, any smoke/unresponsive throttle when cold?
If you change it only go for a Siemens vdo one as the cheap knock off ones last two minutes!!! |
26th Jan 2014 10:18am |
Well, according to the bas website the MAF should rear about 2v from pin 2 at idle and mine reads ...... 0.04
So I guess I need to replace that then What I thought strange was the difference it's made rolling upto junctions, because with the MAF unplugged when I come to a junction now and press the clutch, the revs don't seem to drop like a stone and almost violently rock the engine (like the feeling of staling but with the engine still running) also without the drop off in revs when depressing the clutch, the gear changes seem smoother. I hope when I plug the new MAF in this will be further improved. Cheers Ray |
26th Jan 2014 4:22pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
Are you suggesting T idle there should be approx 2v between pin 2 and earth?
26th Jan 2014 4:54pm |
According to the bas website it should. This is on a td5 so I'm not sure if it's the same on a puma. If you look under misc on the site they offer td5 MAF's click on the page and at the bottom it shows how to check the voltage. I've just ordered a new MAF from bas so fingers crossed there's a difference when it's fitted
Ray |
26th Jan 2014 5:03pm |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
That low volts on a TD5 output means only a couple of things.
Its dead as a dodo or the input feed to it is dead and not powering the maf its self, but if it were this it would generally give 0v out at all. Knowing the td5 like I do I think you will as you suspect and find the maf Is dead and does need to be replaced. We can assume the Input voltage on your car is actually ok as you do have some power out albeit very small at 0.04v Glad the simple test helped you out, thank you for the order. It will be sent out tomorrow for you. Regards Pete. |
26th Jan 2014 6:19pm |
It was a great help I'm ready to fit it as soon as it arrives I'm not impatient honest
26th Jan 2014 6:58pm |
26th Jan 2014 7:07pm |
MAF arrived safely this afternoon and got fitted before the light went I've got a bit of a run out tomorrow to pick up some seats so it'll get a good test with about a 250 mile round trip.
Cheers Ray |
28th Jan 2014 8:18pm |
Glad it arrived in good time. Hopefully it's fixed your problem.
Pete. |
28th Jan 2014 8:31pm |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 |
It will be interesting to see how this pans out as mine is really jerky when backing off the power at low speeds. Things tend to improve when it gets warm though.
28th Jan 2014 10:04pm |
