Home > Technical > Just checking about MAF
Page 2 of 2 <12
mk1collector
Try unplugging the MAF. I ran mine for a couple of days unplugged and the difference wasn't massive but it definately felt smoother while changing gear etc and while picking up revs. My fuel economy was quite a bit down too, how many miles do you get on a tank?
Post #303013 28th Jan 2014 10:23pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Not sure about miles to the tank but I get between about 21 and 23 mpg at the moment. All short journeys around here, although the last tank had some good long runs in it and still only managed to return 22 mpg.
I will disconnect it this morning, although it was new last June! I replaced a cheap one with a vdo unit
Post #303051 29th Jan 2014 7:39am
mk1collector
Yeah it's worth a try! I just did a couple off hundred miles which was more motorway than normal but I seem to have gained my missing 40/70 miles per tank back Mr. Green but we'll see how I does on the stop and start driving around here for a few weeks before I'm totally happy it's back to normal.
Ray
Post #303147 29th Jan 2014 4:21pm
Martin 01
Disconnected mine today and it seems to be running better, seems less jerky when coming off the throttle.
Will get the multimeter out & test the voltage tomorrow and see what that reads.
I also seem to be losing a few MPG's, could the MAF be the culprit ?
Thumbs Up
Post #304208 1st Feb 2014 7:13pm
mk1collector
That sounds exactly what mine was doing. I ordered a new MAF from bas (site sponsor) which came next day and mpg etc is back to normal Thumbs Up
Post #304213 1st Feb 2014 7:37pm
Martin 01
How long can I leave the MAF plug disconnected for ?
When it is disconnected does it cause any harm ?
Will try & get a test on the plug as described on the BAS website.
Post #304860 3rd Feb 2014 9:36pm
Page 2 of 2 <12
