Home > In Car Electronics > Problem with DAB signal
Page 2 of 3 <123>
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
Dunno about the wires ... my mechanic (hubby!) fitted it!
(IIRC, the silly money Entreq one was silly money because it was only FM - if it had been DAB too it would have been a good price - Whistle Rolling Eyes ) Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #301280 22nd Jan 2014 5:58pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
DABONWHEELS sell some very good, and very well received aerials. I bought mine from them, and it's worked pretty well since. DAB signal does get affected more by bad weather especially wind, which we have had a lot lately, but generally, the signal for me is fine. A proper good aerial is not cheap, but you get what you pay for. 1998 110 300Tdi White Hard Top
Post #301335 22nd Jan 2014 7:53pm
danridge
United Kingdom 2004 Defender 90 Td5 XS CSW Java Black
Cheers interlet
Post #301350 22nd Jan 2014 8:30pm
Paddie42
England 2003 Defender 110 Td5 SW Belize Green
Danridge do you fit the Autoleads DAB / FM splitter? I was looking at using this for my DAB radio and wondered if it was any good?
Thanx
Post #350934 11th Aug 2014 7:55am
Dale
United Kingdom 2001 Defender 110 Td5 Tomb Raider LE Bonatti Grey
I have the windscreen one, and it works fine for me. Two things to watch. That the black sticky pad makes good contact with metal of bodywork (to provide an earth) Also, the aerial requires power. Most DAB radios have an option to supply power via aerial socket to the aerial. Make sure this is enabled on the radio, or supply power to the aerial (believe it has it's own power lead)
Post #350944 11th Aug 2014 8:46am
danridge
Go for the windscreen one as Dale describes. I think mines just wasn't fitted 100% right (contacts on the metal). It did work till it slipped or came unstuck. When it worked it was good.
The DAB/FM splitter is pants Smile Its pennies but don't waste em. Get the windscreen one and fit it now when its dry and warm (not cold and damp when I did) Thumbs Up
Post #350976 11th Aug 2014 11:26am
Paddie42
Thank you Dale and danridge for your replies and information Smile
Post #350980 11th Aug 2014 11:39am
Dale
Mine is fitted horizontally like the photo at the start of the thread. I put it at the top of the windscreen, in the middle so it's behind the rear view mirror. Hardly notice it's there. The black box is tight up against the windscreen rubber to ensure that the black sticky pad gets maximum contact with the bodywork. I had to loosen the roof lining so I could get under the front edge of it and stick the pad to the underside of the roof. It also meant I was able to route the wiring above the roof lining, then behind the A-post cover, and in behind the dash. I can take some pictures later when I get home if that helps?
Post #350982 11th Aug 2014 11:53am
Paddie42
Thank you Dale for the advice and offer of pictures.
How long is the aerial wire? I was wondering if it could be attached to the Alpine window and the run forward to the radio? Just a thought....
Post #350983 11th Aug 2014 12:02pm
danridge
You might get away with it - Was about 4 feet maybe if I recall
Post #350984 11th Aug 2014 12:04pm
danridge
This one says 3m Thumbs Up
The Alpine Discreet Screen Film DAB Antenna is an active DAB/DAB+/DMB amplified screen film antenna suitable for all Alpine DAB products.
Structure: Foil Type, self-adhesive
Connection: 3m low-loss cable with angled SMB(f) plug
Dimensions: 47 x 247mm
Total: £34.99 inc Vat
Post #350985 11th Aug 2014 12:07pm
Paddie42
Bow down
Post #350987 11th Aug 2014 12:12pm
Dale
View from outside
Inside view roughly from drivers side
View from inside centre
Post #351080 11th Aug 2014 7:30pm
Buccaneer
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
I went for a sharks fin combined DAB/FM aerial. Obviously can't put it at the back but with the roll cage and the dark paint on my 50th it blends in quite well.
 The Rules:-
1 Buccaneer comes back alive.
2 Chicks dig scars.
GB260
Post #357241 11th Sep 2014 1:27pm
Merlin
On my Kenwood DNX4210DAB the DAB part has stopped. The on-screen menu won't let me turn on the antenna power, as it is greyed out. Any ideas why and what to do?
Merlin
Post #471059 9th Nov 2015 6:58pm
Page 2 of 3 <123>
