Home > Puma (Tdci) > Gearbox Syncros
jddisco200tdi
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Gearbox Syncros
Does anybody else get bad changes from 1st to 2nd, and 2nd to 3rd.
If I rev beyond 3000 rpm I can get a smooth change but otherwise it grinds a bit.
Just trying to work out if its me or do LR need to have a look at it.
The car only has 800 km on it so far. Regards
John D - Defender 110 2.4
Post #2997 1st Aug 2008 3:07am
solmanic
Australia 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Yep. I find the harder I push it, the smoother the changes are. That's not to say I can't get smooth gear changes at lower revs, but it's a bit hit and miss depending on how lazy I am being. 2007 Defender 110
1970 Alfa Romeo 1750GTV
Post #2998 1st Aug 2008 3:18am
Laurie
My TD5 Ninety's been back several times - still not quite right.
They keep telling me it's the selectors - It's bl**dy obviously the syncro.............
Post #2999 1st Aug 2008 7:51am
AndrewS
Both mine change very smooth car like in fact well so I'm told. Ive not driven a 'car' for quite some time. Get it to the dealer and ask to test drive an other to compare Thumbs Up
Post #3001 1st Aug 2008 9:44am
CapeLandy
South Africa
mine too
You just need a few more kilometers to learn the gearbox in my opinion.
My wife uses the Puma as her daily and I have to re-learn the geaqr shioft technique on weekends but you definately need a firm swift movement of the gearstick to engage. Puma 110 - gone
Series III 1973 - going strong
Post #3002 1st Aug 2008 9:46am
jddisco200tdi
Thanks for the replies.
Maybe I just need to be a bit more forceful and I will go and have a drive of a demo to compare. Regards
Post #3045 4th Aug 2008 2:01am
mse
my 1st to 2nd is notcy and ive just put it down to only 4k miles - i certainly dont want another argument with the dealer yet! Mike
Post #3054 4th Aug 2008 4:02pm
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
Seems like my notchy 1st to 2nd shift isn't unique. My guess is the synchro, because if I shift slowly it's OK, thus allowing the gears time to slow down a bit. The only trouble is, especially on a hill start, I run out of momentum and almost come to a standstill. Pulling into swift moving traffic can be a bit tricky too. Land Rover seem to think it's down to the "gear selector rod" being out of position. Sounds like another typical fob-off, I'll let you know how it goes next week when I get it back from the dealer.
Bosun.
Post #3087 6th Aug 2008 6:24am
TJ101
Am sure, if you do a search, this has come up quite a few times,
Seams to be that a "Defender drive style" is called for ie clutch to throttle control timing
My has always been fine, and quite smooth, certainly compared to previous TD5's California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #3090 6th Aug 2008 8:21am
one_iota
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
It takes some adjustment.
I'm used to the fairly sluggish throttle response on the Tdi so the relatively free spinning Puma makes me feel amateurish.
After 1500 km I'm just getting the hang of it along with when to do the First to Second gear shift Mahn
'08 Defender 110
ex '95 Disco 300 Tdi
www.aulro.com
Post #3091 6th Aug 2008 11:15am
Laurie
Bosun wrote:
Land Rover seem to think it's down to the "gear selector rod" being out of position. Sounds like another typical fob-off.
That's what Guy Salmon told me about my TD5 Ninety.
It's obviously the syncro.
Post #3094 6th Aug 2008 12:51pm
mse
on a related note - how much play do you have in your gearsticks in gear and nuetral - mine in 4th has a reasonable amount so much that it rattles at some RPM - apparently normal - one word i have for them B.....Ks Mike
Post #3100 6th Aug 2008 6:33pm
prappo
Russia 2008 Defender 110 Puma 2.4 SW Java Black
I also have some problems with 2nd gear. Sometimes I can hear crunch coming from the gearbox while shift to 2nd. Especially when gearbox is cold. And sometimes (I don't know proper english term for it) it just disengages... Coming from 2-nd to neutral.
It's the only gear I have problems with.
Post #6181 11th Jan 2009 6:28pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Mine has done 13k miles now and has form the start had a notchy 1st to 2nd & 2nd to 3rd but it is better once warm.
Post #6182 11th Jan 2009 6:34pm
Laurie
Sounds just like the box on my TD5 - The only problem I have had, other than those created by my dealer!!!
Post #6188 11th Jan 2009 7:27pm
