Home > My Defender > 2002 110 "black" limited edition
Page 4 of 10 <12345678910>
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
The defender badge was standard fit on earlier models. I seem to remember a recent post on here where someone had retro fitted one.
I am not very good with the search function however, so would struggle to find it for you
James
Post #297720 11th Jan 2014 8:19am
Jimb1978
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...4d0971a774
The genuine defender badges are on ebay
Post #297726 11th Jan 2014 8:28am
shazzy90
A few pics of my black le
Post #297977 11th Jan 2014 11:16pm
shazzy90
sorry i can not rotate pics
Post #297979 11th Jan 2014 11:19pm
Jimb1978
Very nice Thumbs Up
How do you find the Trojan back when you aren't camping? Can things be removed from the middle to give a large enough space, or do you remove completely?
Post #297998 12th Jan 2014 7:08am
shazzy90
i leave it on and it is ok for space for my needs
Post #298041 12th Jan 2014 10:33am
Jimb1978
I found myself in Wales last week, underneath some pretty amazing night skies.
Post #312740 1st Mar 2014 10:04pm
mk1collector
Did I read you were getting your gearbox refurbed? How much was it and did it make a big difference to gear changes?
Ray
Post #335707 4th Jun 2014 3:46pm
Jimb1978
Yes. I replaced the DMF, clutch and fork, rear crank seal and a couple of other bits and bobs in and around there.
The gearbox came from ashcroft and should have had the fifth gear upgrade but due to miscommunication between the garage carrying out the work and ashcroft, a standard unit was sent. The garage only realised when they had completed the job and were filling out the invoice.
It is now back at the garage having the gearbox taken out. They are sending that unit back to ashcroft who will strip it, fit the fifth gear upgrade and send it back for the garage to refit!! Rolling with laughter
Although the garage has made a bit of a boo boo, they have been brilliant about rectifying it and have even paid the extra for the upgrade which was not charged on the original invoice as a goodwill gesture. They even offered to lend me one of their employees personal vehicles as they do not have a courtesy car. I said no to this and dusted off my push bike for the commute to work.
Anyway, the total damage was �1664 including vat in the end. Labour was �360 plus vat.
I did get to drive the reconditioned box for a week because I had a camping holiday booked over half term. The gear selection is so much more positive although the inbuilt crunch between 1st and 2nd is still there if you rush it. Even the mighty ashcroft can't seem to undo that nugget of land rover design. My old box was also binding up in reverse and this has now been sorted. It is a little quieter but I suspect the majority of the noise is coming from the transfer box.
I will let you know what the fifth gear upgrade is like when I get my car back next week 2002 110 td5
Post #335834 4th Jun 2014 9:19pm
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
I have just had the uprated 5th gear on a disco t box it's a supper cruiser now your love it. Want cruise control now!
Post #336021 5th Jun 2014 7:28pm
Pickles
BTR1045,....that's the one!
Pickles.
Post #336073 5th Jun 2014 10:00pm
mk1collector
Cheers for the info Thumbs Up I'm thinking I might need to refurb my transfer box to get rid of some backlash Big Cry
Post #336075 5th Jun 2014 10:04pm
Jimb1978
How much backlash is there ray? When I grab hold of the rear flange I can turn it nearly quarter of a turn and have been advised that is acceptable. Have you checked other less expensive options like drive flanges? 2002 110 td5
Post #336096 6th Jun 2014 5:34am
mk1collector
It's going in for its "garage service" at the beginning of August (I do a mini service in between garage ones) so I'm going to get them to check for ware on the drive flanges, but I just had to change all the oils in t box and gearbox back to original spec because gear changes were starting to get notchy after trying the difflock evo 1 and 2 oils in them last year, and take up on gear changes seems to have got worse and noisier Big Cry With proper oil the gear change is smoother again but the backlash hasn't improved. Fingers crossed for drive flanges Mr. Green
Ray
Post #336123 6th Jun 2014 7:56am
Jimb1978
I also put in a evo 1 and 2 equivalent oil manufactured by Fuchs and found my gearbox was much better at first but soon deteriorated. I reverted back to genuine oils but the damage had already been done. I am not saying it was the Fuchs oil that caused the problems (it could just have been natural wear and tear on an already tired gearbox) but decided to change back just in case. 2002 110 td5
Post #336188 6th Jun 2014 1:36pm
