Home > My Defender > 2002 110 "black" limited edition
Page 6 of 10 <12345678910>
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Ok, so got the shelf fitted today and put the canvas back over the top. I am pretty happy with the results, a lot more secure with easier storage and you wouldn't really know it was there.
The shelf is in two parts so it can be fitted after everything else, or removed when not needed, without the need to strip everything else out around it
Unfortunately, I overlooked the position of the brackets I made for Jerry cans. This means another day with the grinder and welder tomorrow to modify them Big Cry
 2002 110 td5
Post #414327 6th Apr 2015 8:30pm
Jimb1978
I did some rust treatment today, getting busy with the hydrate 80. I knew this area would need attention in a few years when I bought it. Well, I had a scrape and a poke around with a screwdriver and I guess those few years are up!
I think I will do he whole lot. Aluminium replacement panels from yrm metal solutions are not too expensive, and it will save unsightly pop riveted repairs. The sills will be taken, repaired and probably galvanised.
Just when I thought I was getting on top of it all and could continue with the modding. Big Cry 2002 110 td5
Post #419857 28th Apr 2015 8:58pm
mk1collector
Big Cry it's never ending. Every time I look at mine I see another bit that needs sorting Evil or Very Mad Ray
My build thread
Post #419860 28th Apr 2015 9:07pm
Jimb1978
I have been looking for a reason to get back on the push bike. I guess this is it. It is not necessarily too difficult a job I don't think, but it will be the time it takes for parts to be galvanised and for me to paint them. Maybe 3 to 4 weeks?
As with all jobs I am sure it will present other things to me that need doing when it is all stripped down.
How is yours looking behind the triangular sills you took off? Hopefully not like mine!! 2002 110 td5
Post #419914 29th Apr 2015 6:38am
Nice build !
Post #419922 29th Apr 2015 7:21am
mk1collector
Mine seems in pretty good nick but I've still got to sort the holes for the old seat mounts, it's only been a year or so since I fitted the new seats Rolling with laughter Ray
My build thread
Post #419927 29th Apr 2015 8:32am
Jimb1978
GREENI wrote:
Nice build !
Cheers Greeni. She serves her purpose pretty well now. After repairs, I do have some ideas to modernise the looks but nothing major. Maybe black chequer plate and roof rack instead of bare aluminium and anthracite boosts. I might return the grill to black to complete the all black look.
We'll see 2002 110 td5
Post #420287 30th Apr 2015 8:33pm
Jimb1978
I'd publicly like to thank Ian for building my Land Rover. Has anybody else found these pieces of tape in theirs?
Sorry about the rubbish pictures...taken on my phone. This is the second one I have found, both with "ian" written on them. I didn't think anything of the first because the name was not written very clearly. In all honesty, it could have said anything, until I found the second and then I put two and two together. 2002 110 td5
Post #422758 11th May 2015 8:47pm
Jimb1978
That's one side stripped down. The good news is this side is a lot better than I suspected, so no repairing needed. The other side is a bit worse so I shall make a decision on that when it is removed. But I should be able to patch it rather than use the YRM replacement parts I bought, so at least they stay fully genuine.
My wife asked "when will this obsession with land rovers end? This one (defender) looks like your other one did 8 years ago."
How little they understand. Whistle 2002 110 td5
Post #423324 13th May 2015 8:38pm
Pickles
Jimb,...awesome work mate. Is there anything you can't do?
Where did you learn the skills?
Well done, Pickles.
Post #423347 13th May 2015 10:03pm
mk1collector
You've got to love the "mecano" like kit that is a defender Mr. Green keep up the good work! Did you say you were getting the sill/b, c post section galvanised? Ray
My build thread
Post #423350 13th May 2015 10:21pm
Jimb1978
Well done, Pickles.
Taking it apart is easy. It's putting it back together I might struggle with! 2002 110 td5
Post #423371 14th May 2015 6:13am
Nah that's easy as you have the LR Special tool 001 by the NSR wheel Whistle
Post #423373 14th May 2015 6:30am
Jimb1978
I've got two of those for when I break one. Laughing 2002 110 td5
Post #423384 14th May 2015 7:26am
Jimb1978
Yes. I considered just having crimble powdercoaters put on the zinc base coat for me to spray over, but the way the sills are constructed means this would probably trap the rust that has started between the spot welded seems. 2002 110 td5
Post #423412 14th May 2015 8:53am
