![]() | Home > Technical > Steering Wheel Lock |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2051 ![]() ![]() |
Just turning the steering wheel without the key in should make it lock....and you might have to wiggle the steering wheel as you turn the key to make come off again.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5805 ![]() ![]() |
They are not the simplest to activate as the steering is soooo heavy without the engine running, especially if you've got big tyres
![]() Andy |
Gwynne_90 Member Since: 29 Nov 2013 Location: Southampton Posts: 15 ![]() ![]() |
Turning the wheel, as you'd normally do, doesn't seem to work..... Any other ideas on what might be wrong?
Cheers everyone ![]() |
It maybe it is coz your not used to the steering, requiring more force AND movement (there is a lot more play in a Defender) to turn the wheel,if you can turn the steering wheel from lock to lock without the key in the ignition then your steering lock is
Only thing I can think of is to jack the front up and try. If still nothing it must be damaged or broken.
Andy |
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861 ![]() ![]() |
Try laughing at it rather than giggling!
