Home > Tdi > MPG |
orhdpos Member Since: 03 Dec 2012 Location: Hoddesdon Posts: 8 |
Today I filled up at a BP station near Harlow essex put in the bp super disel and added 200mls of 2 stroke, clicked the speedo to zero, small trailer on the back actually a 3 bike clipon trailer with a ply box fixed on the back, was going to Ingst near the old seven brige to pick up a rear axel with discs for defender 90, kept speed at a constant 55- 62 with only a couple of 70 bursts, filled back up at Hoddesdon 320.6 miles later put in 200mls of 2 stroke and 42.73 Litres of disel so 320 miles into 42.92 =7.46 x 4.5 =33.60MPG have I done some think wrong 300tdi with gas flowed head, oil changed and filter, any way more impotant than that what do these numbers on the diff mean
HRC 1124 Rover 21 02 with 95 to thr right on another part 2012 with 1-3 next to it wanted to add the picture but can't do it orhdpos |
19th May 2013 7:39pm |
[quote="jst"]not split hairs i made it 34mpg (33.999mpg) still bloody good
diff - no idea was you towing a trailer |
19th May 2013 8:31pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8136 |
Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
20th May 2013 7:25am |
IKke Member Since: 16 Aug 2008 Location: Brabant Posts: 117 |
I'm following the fuel use and km for over 4 fill ups now and I'm getting 37MPG. I corrected that with 10% due to deviation in Km measurement and it is still 33.7 MPG on average. I only drive it around locally and it has a 200tdi. It's better than what I expected. Scaling the real deal.
20th May 2013 12:27pm |
will be checking my'n over a few tanks normally only short runs but this was a long one do you add 2 stroke and what are your thoughts on it. |
20th May 2013 5:29pm |
I don't add 2 stroke. But it the previous owner fitted a K&N sports filter which may help a bit. I have read on disco3.co.uk that filthy air filters will decrease MPG significantly.
My thoughts on 2-stroke is that i'm unsure about it. I'm still waiting to read a scientific research/paper on this topic. But I can see how it would help to lubricate the injector pump, but other than that I still don't see how it would help. Although there is a great thread about it on freel2.com: http://www.freel2.com/forum/topic878.html?highlight=2+stroke+oil Scaling the real deal. |
20th May 2013 9:43pm |
Culminator Member Since: 30 Apr 2013 Location: West sussex Posts: 305 |
Finally got around to properly measuring the mpg of my 300tdi. Lowered springs, bfg road biased tyres, egr blanking plate, de cat, elec fan, discovery gear ratios and a bit of 2 stroke oil.
Driving sensibly but mainly local roads, 348 miles from brimmed full, took 44.22 litres to return to brimmed full. That equates to a staggering 35 mpg which I'm really pleased with. |
5th Oct 2013 9:39pm |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 |
That doesn't sound too bad i have never owned a 90 tdi but have had two 300tdi disco's one a manual and the other an auto the manual was giving me between 30-32 mpg and the auto gave me between 35-38 mpg so if i get a 300tdi defender 35ish mpg would be great Graham
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
7th Oct 2013 12:23pm |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 |
Bloody Nora ... My Softy 90 get between 23-27 MPG depending on what mood it decides to be in and I record all my MPG's.
Making me think something's up !!?! |
2nd Jan 2014 11:22pm |
Click image to enlarge |
2nd Jan 2014 11:23pm |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 |
My200tdi is similar to that - the average commute is 24-28mpg.
A decent motorway run, sat at 65ish will get me just into the 30s. |
3rd Jan 2014 4:28pm |
smbaker Member Since: 29 Jan 2014 Location: Essex Posts: 5 |
'98' CSW 300tdi and averages 24-28 on local trips mainly. Add 200-300ml 2 stroke every tank.
29th Jan 2014 5:18pm |
Spookytooth Member Since: 19 Jan 2014 Location: Lincolnshire Posts: 202 |
Year old 110XS. 30 plus mpg is impossible - fact 110 SW Aintree Green
30th Jan 2014 8:53am |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6312 |
I presume you mean 'your' 110xs and not 110xs's in general ?
(I know mine is a 2.4 and I can get well over 30 - I wouldn't have thought the 2.2 to be that different?) |
30th Jan 2014 12:48pm |
