Home > Tdi > MPG
Page 1 of 3 123>
orhdpos
MPG
Today I filled up at a BP station near Harlow essex put in the bp super disel and added 200mls of 2 stroke, clicked the speedo to zero, small trailer on the back actually a 3 bike clipon trailer with a ply box fixed on the back, was going to Ingst near the old seven brige to pick up a rear axel with discs for defender 90, kept speed at a constant 55- 62 with only a couple of 70 bursts, filled back up at Hoddesdon 320.6 miles later put in 200mls of 2 stroke and 42.73 Litres of disel so 320 miles into 42.92 =7.46 x 4.5 =33.60MPG have I done some think wrong 300tdi with gas flowed head, oil changed and filter, any way more impotant than that what do these numbers on the diff mean
HRC 1124
Rover
21 02 with 95 to thr right
on another part 2012 with 1-3 next to it
wanted to add the picture but can't do it
orhdpos
Post #236985 19th May 2013 7:39pm
jst
not split hairs i made it 34mpg (33.999mpg) still bloody good
diff - no idea
date? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #237019 19th May 2013 8:29pm
orhdpos
[quote="jst"]not split hairs i made it 34mpg (33.999mpg) still bloody good
diff - no idea
was you towing a trailer
Post #237020 19th May 2013 8:31pm
jst
Question Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #237095 20th May 2013 7:25am
IKke
Netherlands 1986 Defender 90 200 Tdi SW Keswick Green
I'm following the fuel use and km for over 4 fill ups now and I'm getting 37MPG. I corrected that with 10% due to deviation in Km measurement and it is still 33.7 MPG on average. I only drive it around locally and it has a 200tdi. It's better than what I expected. Scaling the real deal.
Post #237152 20th May 2013 12:27pm
orhdpos
will be checking my'n over a few tanks normally only short runs but this was a long one do you add 2 stroke and what are your thoughts on it.
Post #237233 20th May 2013 5:29pm
IKke
I don't add 2 stroke. But it the previous owner fitted a K&N sports filter which may help a bit. I have read on disco3.co.uk that filthy air filters will decrease MPG significantly.
My thoughts on 2-stroke is that i'm unsure about it. I'm still waiting to read a scientific research/paper on this topic. But I can see how it would help to lubricate the injector pump, but other than that I still don't see how it would help.
Although there is a great thread about it on freel2.com: http://www.freel2.com/forum/topic878.html?highlight=2+stroke+oil Scaling the real deal.
Post #237339 20th May 2013 9:43pm
Culminator
Finally got around to properly measuring the mpg of my 300tdi. Lowered springs, bfg road biased tyres, egr blanking plate, de cat, elec fan, discovery gear ratios and a bit of 2 stroke oil.
Driving sensibly but mainly local roads, 348 miles from brimmed full, took 44.22 litres to return to brimmed full. That equates to a staggering 35 mpg which I'm really pleased with.
Post #271727 5th Oct 2013 9:39pm
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
That doesn't sound too bad i have never owned a 90 tdi but have had two 300tdi disco's one a manual and the other an auto the manual was giving me between 30-32 mpg and the auto gave me between 35-38 mpg so if i get a 300tdi defender 35ish mpg would be great Smile Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #272018 7th Oct 2013 12:23pm
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
Bloody Nora ... My Softy 90 get between 23-27 MPG depending on what mood it decides to be in and I record all my MPG's.
Making me think something's up !!?!
Post #295319 2nd Jan 2014 11:22pm
taazzukcb
Post #295320 2nd Jan 2014 11:23pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
My200tdi is similar to that - the average commute is 24-28mpg.
A decent motorway run, sat at 65ish will get me just into the 30s.
Post #295476 3rd Jan 2014 4:28pm
smbaker
United Kingdom 1998 Defender 90 300 Tdi SW Cobar Blue
'98' CSW 300tdi and averages 24-28 on local trips mainly. Add 200-300ml 2 stroke every tank.
Post #303163 29th Jan 2014 5:18pm
Spookytooth
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Year old 110XS. 30 plus mpg is impossible - fact 110 SW Aintree Green
Post #303340 30th Jan 2014 8:53am
Caterham
I presume you mean 'your' 110xs and not 110xs's in general ?
(I know mine is a 2.4 and I can get well over 30 - I wouldn't have thought the 2.2 to be that different?)
Post #303404 30th Jan 2014 12:48pm
Page 1 of 3 123>
