Home > Technical > Engine Oil Viscosity
oilman
Viscosity is the most misunderstood aspect of oil and yet it is the most important.
Viscosity is the force required to shear (break) the oil at a certain speed and temperature. Oils work because they have viscosity; the drag of a rotating part pulls oil from a low-pressure area into a high pressure area and “floats” the surfaces apart. This is called “hydrodynamic lubrication” and crankbearings depend on it.
Oil must be capable of flowing at low temperatures, so that it gets around the engine in a fraction of a second at start-up and must protect engine components at high temperatures without evaporating or carbonising and maintain adequate (not excessive) oil pressure. Many people think that the thicker the oil, the better the protection, but if the oil is too thick, it will not flow properly, leading to reduced protection.
The numbers on every can of oil indicate its performance characteristics when new but there are many misconceptions on what these numbers actually mean.
For multigrade oils you will see two numbers (for monograde oils only one). The first is followed by a “w” and is commonly 0, 5, 10, 15 or 20. The second number is always higher than the first and is commonly 20, 30, 40, 50 or 60. The first and second numbers ARE NOT related.
The “w” number (0, 5, 10, 15 or 20)
When multigrade oils first appeared, a low temperature test called “w” (meaning “winter” not weight) was introduced. Using a “Cold Crank Simulator", the test measures the oils ability to flow at low temperatures. ALL oils are THICKER at low temperatures than at high temperatures but the lower the “w” number, the quicker the oil will flow at low temperatures.
The second number (20, 30, 40, 50 or 60)
This number is known as the SAE (Society of Automotive Engineers) number and is measured in “Centistokes” (cst) at 100C. Centistokes (cst) is the measure of a fluid's resistance to flow (viscosity). It is calculated in terms of the time required for a standard quantity of fluid at a certain temperature to flow through a standard orifice. The higher the value, the thicker the oil.
An oils cst at 100C determines its SAE rating within the following parameters.
SAE 20 = 5.6 to less than 9.3cst
SAE 30 = 9.3 to less than 12.5cst
SAE 40 = 12.5 to less than 16.3cst
SAE 50 = 16.3 to less than 21.9cst
SAE 60 = 21.9 to less than 26.0cst
ALL oils labelled 40 must fall within the SAE parameters at 100C so everything from a monograde 40 to multigrade 0w-40, 5w-40, 10w-40, 15w-40 or 20w-40 are approximately the same thickness at 100C.
Some oil companies label oils as SAE 35, 45 or 55, but as you can see from the above figures, there isn't a SAE 35, 45 or 55. This "could" be because they are approximately on the boundary of the two grades, but as we don't deal with any of those I can't really comment further.
Summary
Cold start.
A 5w-40 will flow better than a 10w-40.
A 10w-50 will flow better than a 15w-50
A 5w-40 is the same as a 5w-30
At operating temperatures.
A 10w-50 is thicker than a 10w-40.
A 15w-50 is thicker than a 5w-40
A 0w-40 is the same as a 10w-40
If you look above, you will see that the figures quoted do not indicate at all as to whether the oil is synthetic or mineral based... Well except for 0w oils as synthetic PAO basestock is required to acheive this viscosity.
Generally the oil you use should be based on the manufacturers recommendation found in the owners manual, but then modifications, climate and the type of use can affect that recommendation. If you are unsure of what is the correct recommendation for your car and would like to know more please contact us here oilman@opieoils.co.uk
With thanks to John Rowland of Fuchs/Silkolene
Tim and the Opie Oils team Use the code DEF2 and get 10% Club Discount
View Opie Oils Current Offers Here > >
oilman's website: http://www.opieoils.co.uk/ - register for news and offers
email: sales@opieoils.co.uk
phone: 01209 202944
Post #272765 10th Oct 2013 1:56pm
radar54j
Is mobile 1 oil ultimetly the best best oil for a modern diesel ? Am I ok to put mobile 1 in my 2005 defender on 70K ?
regards alan [/code]
Post #294277 30th Dec 2013 5:00pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Thanks oilman...good explanation Wink
Post #294785 1st Jan 2014 8:34am
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Great explanation,My advice to all who do their own servicing would be print this off and paste it to your workshop/garage wall for future reference. Thumbs Up 2005 Td5 90 XS
Steve
Post #294804 1st Jan 2014 10:00am
oilman
Hi Alan
Mobil make a fair few oils in their Mobil 1 range, some being good options for your Defender, others are poor choices. I'd probably use a 5w-40 in yours, and the Mobil Super 3000 is a decent choice. The best options would be something like the Fuchs Pro S, Red Line, Millers CFS, Gulf Competition or Motul 300V. Fuchs GT1, Castrol Edge, Millers XF Longlife, Motul X-Cess, Mobil Super 3000 and Gulf Formula G are good, cheaper options.
http://www.opieoils.co.uk/c-656-5w-40.aspx
Mobil 1 0w-40 New Life is fine to use, although as it's so thin when cold, you might find it rattles a bit from cold.
Tim Use the code DEF2 and get 10% Club Discount
phone: 01209 202944
Post #295091 2nd Jan 2014 11:26am
rsms
Slovenia
Hello,
some very good advices here! I`ve put Motul 8100 Eco-nergy 5W30 into my unmodified TD5 - is that a good idea?
Peter
Post #295167 2nd Jan 2014 5:51pm
oilman
Hi
That's a good choice for a TD5.
phone: 01209 202944
Post #295370 3rd Jan 2014 8:52am
dgardel
Italy
It is important the HTHS characteristic also!!!!
my Defender has 98000km and I always used the Mobil1 5w50 peak life. Fantastic oil very good mid-high HTHS and wear protection oil.
the engine do not eat oil and is going strong (remapped, updated intercooler and hybrid turbo from new) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #295427 3rd Jan 2014 1:12pm
