Home > Maintenance & Modifications > LED front sidelights won't come on!
Jim_Bean
I've bought a full set of LED lights and the replacement wipac relay. I've only swapped out the sidelights so far.
The stop/tail lights work fine but the front ones will not come on.
If i place the original sidelights back on they work fine - its not a fuse.
Any ideas?
Post #293642 28th Dec 2013 1:38pm
Byronavitch
England 2011 Defender 90 Puma 2.4 HT Stornoway Grey
Read somwhere you may have to swop the wires around might need other more knowledgable forum members to confirm
Post #293643 28th Dec 2013 1:43pm
Test the lights on a small battery to check they work I.e. A 9v after that reverse the polarity and try that.
If none of that works something's up with the lights.. Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #293644 28th Dec 2013 1:44pm
Jim_Bean
Thanks guys - i'll swap the wires around and see what happens!
Post #293645 28th Dec 2013 1:45pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
If swapping wires round does not work, lights are faulty, but more than likely swap round... LEDs require correct specific inputs. 1998 110 300Tdi White Hard Top
Post #293653 28th Dec 2013 3:10pm
Jim_Bean
Tried swapping the wires around on the sidelight and it worked fine.
It looks like i'll have to change them over on EVERY unit including all the indicators.
Real PITA.
Post #293659 28th Dec 2013 3:25pm
That shouldn't normally be the case, the RDX ones I recently fitted on mine matched every wire colour.
It's either the lights wires have incorrect polarity or the LR does but most likely the lights.
LED's are polarity sensitive so unlike a standard incandescent light bulb power can only pass through one way.
If I was you if you have one get the multimeter out and set it to voltage if you have one, then turn the sidelights on and eart the Neg probe and check where there is power with the positive probe.
It should be the red or corresponding power wire that is live, if it's not then it's the LR that has wrong polarity hence the incandescent bulbs working.
You could then quickly rule that out and blame the lights. Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #293695 28th Dec 2013 5:17pm
Jim_Bean
Actually just found this video and comments from First Four.
https://www.firstfour.co.uk/item/2174193/d...tor--amber
Looks like the polarity switched in Defenders Post 1998!
Post #293698 28th Dec 2013 5:24pm
There is your answer then. Thumbs Up Good find. Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #293702 28th Dec 2013 5:38pm
Jim_Bean
Wish i'd found that video before my "helpful mate" had cut the wires to change the polarity!
Post #293721 28th Dec 2013 6:48pm
