Home > In Car Electronics > CB & aerial UPDATE now fitted :)
Page 3 of 4 <1234>
JWL
Sorry but for a decent cb signal I'm afraid you're stuck with a purpose made cb aerial. If you can have a chat with the likes of Jim from 4x4cb he can give you no end of pointers for the best solution to your wants. He is difficult to contact but the best way is to fire off an email with the questions you want answering and sit patiently, he often only looks at his emails at some godforsaken hour in the morning which can be a little offputting when you want an answer NOW! Whistle
Post #283485 19th Nov 2013 2:02pm
Cheshire110
ok thanks guys, looks like i'll have to get a proper CB aerial.
think thunder pole do one as a deal with the polar venus so i'll probably go for that or get one from maplin or the CB shack down the road. Cheers, David
Post #283497 19th Nov 2013 4:49pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Could you not use a magnetic based aerial on the roof by fixing a steel plate to the roof. The plate could be suitably finished and secured either by permanent fixings or some form of adhesive or double sided tape. Whistle LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #283530 19th Nov 2013 7:07pm
Cheshire110
interesting idea! will give it a look.
have also seen the 'quick aerial release' adapters available which is an option,
thanks everyone Cheers, David
Post #283595 19th Nov 2013 9:59pm
Cheshire110
So my birthday came and went and a CB and aerial arrived Smile
Fitted it today, very pleased with it!
I see they are all sideways, that's better than upside down which they usually are... Hmm
But you get the idea anyway, can unscrew aerial, unplug hand unit and it's all neat and you'd barely know it's there, also comes with battery pack and short aerial to use it as a handheld.. Cheers, David
Post #290248 14th Dec 2013 11:42am
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Hmmm, if you hit a branch you either sheir it off or dent your roof... no?
Post #290250 14th Dec 2013 12:11pm
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
I have had a gutter mount on mine and never had a problem. Wherever you put a cb Ariel there is always potential for harm, not solely relating to the gutter mount, if every branch took every Ariel off we wouldn't have them Thumbs Up ===================================
Steve
90 xs sw in Stonoway Grey - Sold
110 USW X-TECH
Post #290268 14th Dec 2013 3:43pm
Lishlandy
Saying that Zone does have a point, my last one got broken in half.
I have a wing mirror mount on order Embarassed ===================================
Steve
110 USW X-TECH
Post #290269 14th Dec 2013 3:46pm
GUM97
Nice setup, I actually expected the unit to be a bit bigger! Thumbs Up An engine to TDi for!
Post #290282 14th Dec 2013 4:43pm
zone30
It's how the bracket is positioned. It presses against the roof and I think it'll push into it. Even the natural wiggling of the antenne will start scratching the paint of.
I'd mount it at the back of the car so it swivels away from the car or turn the bracket around so it further away from the roof.
By the way, I have the same bracket on my roofrack.
Post #290293 14th Dec 2013 5:21pm
Cheshire110
Cheers guys, good point I hadn't thought much about..
The aerial itself is very flexible so it's only really a branch hitting the bracket itself which is an issue, it feels very solid which I guess is part of the issue.
The gutter itself is filled with a rubber/foam lining so there's a bit of give there and it actually could probably slide a little if it took a hefty knock, but it's a good point and I may consider moving it rearwards...
I'm only going to fit the aerial for laning trips so I'll have another look for the Xmas outing.. It only takes a few min to fit so can move it easily if it's a problem!
Well pleased though... Cheers, David
Post #290297 14th Dec 2013 5:32pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Depends on the laning you plan on doing, but most of the stuff we do involves pushing through low hanging hedges/trees at some point and anything on the Defender above windscreen height takes a battering.
I made a bracket that I clamped between the top rear door hinge and the body work (I didn't want to drill any holes in the roof) and fastened the CB aerial to that. Its protected by the roof of the car but high up and does a great job.
I can post some pics if you are interested.
cheers
simon
Post #290311 14th Dec 2013 5:58pm
Cheshire110
I can picture exactly what you mean, sounds a good idea..
I have some time before I next go out so I could move it the the rear somewhere, I agree it will be much more protected behind the car, although I do normally go very slowly and am pretty careful but better safe than sorry
Cheers for the advice guys Cheers, David
Post #290314 14th Dec 2013 6:08pm
Cheshire110
^ changed the aerial fitting to the rear, much better actually - thanks for the advice.
Just need an extension now to reach where I want the handset to be
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Cheers, David
Post #292518 22nd Dec 2013 8:13pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I had the same mount fitted to a 90 a couple of years ago, the only problem was that when it vibrated it rubbed on the roof and took the paint off. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #292520 22nd Dec 2013 8:22pm
Page 3 of 4 <1234>
