Home > Td5 > Poor running after about 10 miles
jonesie
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Corris Grey
Hello festive chaps and chapes's
Not sure what to do......about 8 weeks ago replaced the injector loom and purged all oil out of the harness and ECU.
(59000 miles)
Couple of weeks ago the following started to happen, on startup td5 runs fine...after about 10 miles of stop start town type driving it misfires and runs on 4.
Took to local independent L/R dealer who carried out full service and replaced fuel filter and cleaned around injectors said it was running fine.
Ran for ....yes you guessed it, 10 miles and it's missing again.
Can't take it back to them until the new year.
Had the following slight mods for about last 10,000miles, EGR removed, panel filter and decat pipe.
Any thoughts?
Thanks for reading this and Merry Christmas.
Jonesie it's so wet here thinking of building an arc. Series I 86" Petrol orig side valve (daily hack)
VW Tiguan ( bit bland but very comfy )
Porsche 997.2
790 Bonnie
Post #292251 21st Dec 2013 5:51pm
jst
fuel pump getting hot and not producing right pressure in rail? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #292324 21st Dec 2013 8:26pm
jonesie
Thanks for that James.
It's now doing it from startup............ Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #292410 22nd Dec 2013 2:04pm
K9F
It should be easier to find the root-cause now if it's doing it straight away which is good news. Do you have or know of anyone in your area with a fault code reader? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #292469 22nd Dec 2013 6:03pm
jonesie
Thanks K9F,
Yeah it's been in to the local Indy ( Nick Kerner eng,) who claim it's been plugged in ...... Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #292481 22nd Dec 2013 6:28pm
landy andy
New panel filter? Paper or oil?
Have you tried with MAF disconnected?
Andy
Post #292489 22nd Dec 2013 6:45pm
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
If this helps...
If you can make the Oxon pub meet on the 8th Jan http://www.defender2.net/forum/topic25201.html
I can bring along my Nanocom and we can check for fault codes and live readings.
Appreciate you will probably want it sorted prior to that though... Jon - 110 td5 [sold]. Currently Defenderless.
Post #292493 22nd Dec 2013 6:54pm
jst
is the fuel pump making more noise than normal? whats the fuel pressure at the regulator? you can T into it and take a reading if your brave. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #292501 22nd Dec 2013 7:35pm
jonesie
Thanks for those replies.
Air filter is a pipercross oil.
Got to say I haven't tried it with the maf disconnected but will in the morning.
The fuel pump seems the same.... Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #292581 22nd Dec 2013 11:05pm
jonesie
Sorry forgot to add haven't checked the fuel pressure yet and it wouldn't make it Oxon at the mo because it is barley running. Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #292582 22nd Dec 2013 11:07pm
jonesie
Makes in difference with the maf disconnected..... Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #292658 23rd Dec 2013 11:35am
Laurie
Probably a silly idea but have you tried it with the filler cap off?
The tank breather might be blocked.
Post #292660 23rd Dec 2013 11:52am
jonesie
It was No1 injector........ Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #292992 24th Dec 2013 5:28pm
