Home > Td5 > Warm up in cold weather
Page 2 of 3 <123>
Ah, ok. That puts a slightly different slant on it. I'm not sure that really translates as saying the rad is on the limit of capacity Confused Darren
Post #289339 10th Dec 2013 10:26pm
Laurie
....but Land Rovers are made for the sort of use I give mine, therefore there should be some latitude......?
Post #289340 10th Dec 2013 10:30pm
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
My 90 used to be a 3.9 V8, warmed up in about 2 miles/minutes but was a proper PITA when stuck in traffic or at slow speeds like green laning..
Big change when I swopped it for a Td5 - now it takes about 5-8 miles to warm up if travelling out of town, but travelling at slow speed from home into town (about 5 miles) it pretty much doesn't properly warm up at all. Recently been working 6 miles from home, but in the middle of town, taking about 25 minutes in slow moving traffic. Hardly ever got to proper warm... Rolling Eyes
As part of our expedition prep we fitted a Mad Man monitor. Now I know the exact temperature it gets to when I start feeling luke warm air - about 70 degrees, and when I start getting proper warm air - when it is fully warmed up at about 88 degrees. Pushing it a bit in warm weather it reaches about 90 then quickly drops back to 88 or so. In heavy traffic it struggles to stay at full operating temperature and sometimes starts to cool down - completely the opposite of the V8!!
Although it is cold in winter, that is less stressful than having sitting in traffic on a hot day watching the temperature go up and up and wondering where I might be able to turn off and get some speed up to cool it down! I just put an extra layer on, big coat, wooly hat and gloves! Whistle Thumbs Up Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #289343 10th Dec 2013 10:32pm
I agree, but going by what you've now told us it would appear that you've exceeded it. Whether the specifics of what you've done (both the dunking and cleaning) are a reasonable expectation or not is a bit difficult to judge from here. Darren
Post #289350 10th Dec 2013 10:42pm
Laurie
I don't pressure wash the rad because of the risk of bending fins.
I take the front grill off and use a normal garden hose nozzle on both the front and back of the radiator until the water runs clear.
I then start the engine and run at about 1K revs. I hose the front through the reachable parts of the radiator and via the air-con rad until the water runs clear.
That should be sufficient.
My car is completely standard. I was considering chipping but this has put me off.
It does only flick into limp mode when towing my 1.5 ton caravan at 60mph on motorways in hot weather.
If I drop the speed to 50mph it's fine.
Post #289356 10th Dec 2013 10:58pm
jimbob7
Lou Sparts wrote:
I have thought about lagging the heater box under the bonnet to stop it being blasted with cold air.Anyone tried it ?
Did it a few weeks ago usin the bubble foil type stuff with foam underneath and half a dozen cable ties, due to the awkward shape of the airbox I cut out separate pieces then glued them together before cable tying it to the heater box also lagged teh 2 pipes going to and from the heater box (28mm foam pipe is a perfect fit + cable ties).In temps of 4-5 deg about 1.5 miles and the air temp starts to increase,4-5 miles and the heater is pretty much up to maximum temp.I also stuck/cable tied thick felt to the underside of the bonnet.Not had chance to try it at sub zero yet,frikin heatwave of a December we havin,meh! I think mostly comes from having a working thermostat and properly adjusted controls so it may not be making a massive difference but I'm not taking it off until we've had proper cold weather.
My old Corsa didn't warm up any quicker,also bort a rad muff but not needed it yet,lol. Pov.spec,ftw. 2006, 110,TD5.
Post #289359 10th Dec 2013 11:02pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
Laurie - sounds like you have problem with your cooling system. You should be able to tow 3.5 tonnes all day long in the summer on a motorway. Suggest you double check your rad, viscous fan and serpentine belt. I certainly wouldn't have a remap until you've sorted the cooling system out, doesn't sound like your rad would cope with it at the moment. Confused 2007 TD5 90 Hard Top
Post #289392 11th Dec 2013 7:48am
geobloke
Lou Sparts wrote:
Its my understanding that the electric fan in front of the radiators of A/C models is supposed to cut in at 28 degrees ambient temperature to assist cooling.
Then there is something definitely wrong with mine as it never cuts in... also sounds like a bag of spanners in a cement mixer when I finally got it working again... I need a new fan for sure...
Post #289399 11th Dec 2013 8:08am
Laurie
It's been doing it as long as I've owned it.
It's been properly serviced by a company I trust.
Maybe it's time to investigate............
Post #289442 11th Dec 2013 11:05am
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
@ geobloke, How often does it reach 28 degrees celcius in Wales Whistle 2005 Td5 90 XS
Steve
Post #289444 11th Dec 2013 11:29am
Landlord
Do you have to top up the coolant during the summer.
Could be as simple as the expansion bottle cap is faulty and therefore your system is not maintaining pressure under heavy load in the summer Thumbs Up 2007 TD5 90 Hard Top
Post #289447 11th Dec 2013 11:41am
Laurie
Never had to top up anything.
The ECU is designed to put TD5s into limp mode at 105°C
We belted it up and down a dual carriageway until it reached that, measured on an analytical plug-in.
Post #289449 11th Dec 2013 11:50am
Landlord
Seems strange, should be able to take it easily. Forget the caravan, if you ventured down to the Sahara you'd probably have the same issues, many Landy's with air con head that way without issues - many also get issues Confused
TD5's and TDi's usually have to much cooling ability. I had a Lotus which did the same a few years back turned out to be the electric fan coming on at the wrong temperatures.
If you have electric fans it might be worth checking the cut in / out temperatures.
You also say it "only stated after going through some gloop" - hint is in your post then - something wrong somewhere. Fan sensor, temp sensor, rad fins or fan itself not working correctly or a combination. Thumbs Up 2007 TD5 90 Hard Top
Post #289455 11th Dec 2013 12:43pm
Laurie
Everything appears to operate as it should.
After a number of 'limps' the ECU switches the air-con fan on. This then comes on continuously on the ign switch until an ECU reset is carried out.
Post #289468 11th Dec 2013 1:14pm
Lou Sparts
I think the problem is probably a build up of dried mud on your radiator, as you say not easy to clean when you have A/C.
On one of my previous Defenders i had to remove the radiator to clean it properly after a day at a pay and play site. 2005 Td5 90 XS
Steve
Post #289473 11th Dec 2013 1:21pm
Page 2 of 3 <123>
