Home > Td5 > How do I get the windscreen washer nozzle out?
Gareth
My nozzle is blocked up, and needs taking out for a proper clean or replacement. Before I start ripping the dash apart, is there an easy way to get it off?
I realise I could probably just pull it off, but its the getting back on that concerns me a little.
2003 model TD5 with newer style dash, and air con if that makes any difference. Thumbs Up 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #288747 9th Dec 2013 12:26am
They should be the same as the rear, which has a nut on it. So behind each there is a threaded section and a nut.
You might be able to get access just through the centre dash.
Thumbs Up
Might be worth trying a needle or pin downs the nozzles plenty of times too first. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #288748 9th Dec 2013 12:30am
wait until it gets cold and they pop off ...
they are a 2 piece unit, the outside bit pulls off Thumbs Up
Post #288765 9th Dec 2013 9:10am
Gareth
Cheers Chaps. Already tried the needle, and when I tried to re-align the nozzle a bit, the needle snapped off flush Sad
I guess I am going to give it a pull and see what happens Shocked 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #288768 9th Dec 2013 9:23am
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
i,m not sure but you may be able to get to the back of the washer jet on a Td5 if you remove the ash tray from the top of the dash. 2005 Td5 90 XS
Steve
Post #288769 9th Dec 2013 9:28am
Gareth
Ok, thats worth a look. Thumbs Up 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #288771 9th Dec 2013 9:39am
I removed the central pod then theres a screen held on with 4 self tappers easy access then
Post #288772 9th Dec 2013 9:46am
