![]() | Home > Td5 > How do I get the windscreen washer nozzle out? |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1116 ![]() ![]() |
My nozzle is blocked up, and needs taking out for a proper clean or replacement. Before I start ripping the dash apart, is there an easy way to get it off?
I realise I could probably just pull it off, but its the getting back on that concerns me a little. 2003 model TD5 with newer style dash, and air con if that makes any difference. ![]() 1966 S2a 109 aka Betsy |
wait until it gets cold and they pop off ...
they are a 2 piece unit, the outside bit pulls off ![]() |
Cheers Chaps. Already tried the needle, and when I tried to re-align the nozzle a bit, the needle snapped off flush
![]() I guess I am going to give it a pull and see what happens ![]() 1966 S2a 109 aka Betsy |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
i,m not sure but you may be able to get to the back of the washer jet on a Td5 if you remove the ash tray from the top of the dash. 2005 Td5 90 XS
Steve |
Ok, thats worth a look.
I removed the central pod then theres a screen held on with 4 self tappers easy access then
