Home > Puma (Tdci) > does coolant need topping up frequently ? |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
just in case anyone needs a top up with the correct coolant the part no. is STC50529. Its a 1litre bottle and costs £8 from your dealer (got some yesterday)
3rd Dec 2011 8:42am |
Andreas Schuback Member Since: 25 Oct 2011 Location: scotland Posts: 31 |
coolant leak at cap on expansion tank, new cap fitted still leaking, new expansion tank fitted problem solved under warranty game on.
5th Dec 2011 8:46pm |
Flaskandsarnies Member Since: 05 Dec 2013 Location: Stirling Posts: 2 |
Yes I had this on our 2.4 defender. First the dealer suggested I had been fiddling with the cap of the expansion tank and had put the seal in upside down. Suitably amused I let him ramble on. Then it leaked through the cap again. New cap fitted. It then split the expansion tank. I fitted a new tank and cap and it was fine for months. Now the cap is leaking again. No sign of head gasket problems and it just looks like the normal poor quality Landrover product and parts matched with ridiculous labour ares...yes it's British apart from the Ford improvements and the new parent company, what a product. |
5th Dec 2013 11:20pm |
There have been a couple of queries on coolant level recently so its interesting to note that its two years since I first expressed these concerns. And since - soon afterwards- I just let it settle to about 10mm below the Full line it honestly hasn't budged since.
6th Dec 2013 8:48am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2638 |
Yep, and should be replaced every year as a service item. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
6th Dec 2013 9:47am |
