Home > Maintenance & Modifications > Rear Spring Replacement
Page 2 of 3 <123>
Tarrel
Scotland 2012 Defender 110 Puma 2.2 USW Santorini Black
Cheers for that, BM. Just to clarify;
Would the standard LR springs be the CSW ones that Martin refers to? (The white / green ones?)
Is it a specfic model of Koni shock that you have fitted?
Thanks
Tarrel 2012 Defender Utility Wagon
1981 SIII 88 inch SW
Follow our blog: www.newlifeinnorthernscotland.blogspot.co.uk
Post #241862 7th Jun 2013 10:30pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Hi,
Mine is now set up for the 90 4 seat station wagon (2400 Kg) as shown below.
I used Koni Heavy Track not the Raid which are very heavy duty and costly
Road spring data
Road spring Part number Colour code
90 2 seat utility (2400 Kg)
Front - Driver's side REB500200 Red/green/white
Front - Passenger side REB500220 Red/green/orange
Rear - Driver's side NRC 9448 Blue/red
Rear - Passenger side NRC 9449 Yellow/white
90 2 seat utility (2550 Kg)
Rear - Driver's side RKB101230 Green/yellow/red
Rear - Passenger side RKB101240 Green/yellow/white
Rear - Driver's side RKB500290 Red/green/green
Rear - Passenger side RKB500280 Red/green/red
90 4 seat station wagon (2550 Kg)
Rear - Driver's side RKB500270 White/green/pink
Rear - Passenger side RKB500310 White/green/purple
LHD 110 2 seat utility, 5 seat station wagon and 5 seat crew cab (3050 Kg)
Front - Driver's side NRC 8044 White/white
Front - Passenger side NRC 8045 Yellow/yellow
Rear - Both sides RKB101111 Purple/brown
RHD 110 2 seat utility, 5 seat station wagon and 5 seat crew cab (3050 Kg)
Front - Both sides NRC 8045 Yellow/yellow
LHD 110 7 seat station wagon (3050 Kg)
Rear - Both sides RKB500300 White/green/green
RHD 110 7 seat station wagon (3050 Kg)
Rear - Both sides RKB500300 White/green/gree BM52
Post #241865 7th Jun 2013 10:48pm
Tarrel
Thanks for the comprehensive reply! Thumbs Up 2012 Defender Utility Wagon
Post #241954 8th Jun 2013 11:55am
MartinK
Yep - as BM52 says...
Moving from USW to CSW shocks, combined with Koni Heavy Trak gives a great improvement - especially at the rear (front benefits are less pronounced).
The ride is much less choppy, and SWMBO is a lot happier... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #242464 10th Jun 2013 10:08am
Tarrel
Actually, having read these posts, I did a small experiment over the weekend. Dropped the front tyre pressures to 28 and the rears to 35 (they were on 42), and put 150kg of wood briquettes in the load area. What a difference! Definitely prompted me to make some changes to the suspension.
I'm really surprised at how high the recommended rear tyre pressures are on the USW (as per the label on the B-pillar) - 48psi for light loading and 65psi fully laden / towing??
If this is correct, is it OK to run at 35 on the rear? The tyres certainly don't look under-inflated. 2012 Defender Utility Wagon
Post #242466 10th Jun 2013 10:19am
Welly911
Cheers bm52
Many thanks for all the good write up and awesome information. Would fitting a new set of 110 Station Wagon (3050kg) onto the rear of my 110DC make much of a difference? Cheers mike
Post #258572 14th Aug 2013 9:23am
Carlosbeldia
Columbia 2001 Defender 110 Td5 SW Epsom Green
I'm going this weekend from CSW to HD (130 ones) springs as I usually goes heavy every weekend. I'm putting Cellular Dynamics springs (Koni can't be delivered to Colombia), hope this improve my handling when loaded. Genuine springs failed after about 20 trips to the farm loaded with 1800 kg. Not big fail, they only loose some height and reaction when big potholes in the road.
Post #287992 5th Dec 2013 6:54pm
yostumpy
Put gen LR Wolf spec rears on my 110, and hd + 1" on the front. Quite stiff, corners as if on rails, but I do load it up 'sometimes', and head across that France.
Post #389519 17th Jan 2015 7:51pm
Andy RV
Has anyone changed the rear springs on their 90?
My hardtop can be a bit harsh at times.
Post #418955 25th Apr 2015 4:09pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Martin,
Thanks for a great write up. Looking to order some spring this week.
I didn't see a response on what you thought of the modification, so was hoping you or others could give me some feedback on this before I spend my pennies.
Thanks, Scott... Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #429624 8th Jun 2015 9:19pm
MartinK
Scott - sorry thought I had:
This is a real improvement. However it's still not what I really want, so I have spoken to a couple of supplier about a -1" lowering at the back, and also maybe 20% softer springs (USW springs are slightly shorter than CSW springs, so you'll also notice this with headlamp alignment!). -1" will drop the rear ride height (unladen) to something slightly under original USW spec.
Don't also forget that a USW will be slightly lighter at the back than a CSW (no extra seats in the back, no side windows), so with the same springs, the USW will still be a harder ride than a CSW...
Then...the thing with softening the springs is that it's more likely to lean too much in corners, so may have to uprate the rear anti-roll bar (ARB) at the same time to keep the road-manners acceptable.
Some suppliers do uprated ARB and spring kits...still investigating... This is getting expensive Smile Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #429671 9th Jun 2015 7:03am
ozzie1989
Hi Martin,
I apologise for missing your original write up, I did read that post but completely missed it was you! Doh!
Thanks for the in depth analysis, I have just spent 2 weeks with about 300k of gravel in the back (I wasn't intending it to be there that long) and it drove like a dream - well apart from the stopping distance and fuel economy!
I think I will still order these up as a starting point, I carry about an additional 50kg permanently over standard at the rear anyway so hopefully this will account for the lack of seats vs the CSW.
Thanks again, Scott... Now: 2010 2.4 TDCi 110 Utility Wagon
Post #431406 16th Jun 2015 5:41pm
nitram17
bm52 wrote:
Hi,
Road spring data
Pardon my ignorance but do the springs have different ratings depending whether they are offside or nearside?
Post #431498 16th Jun 2015 9:29pm
ozzie1989
They don't have a different spring 'rate' but the drivers side will be slightly longer (regardless of LHD or RHD I believe) on some models where 2 part numbers are listed for the front. This is down to weight distribution.
Interestingly the newer ones don't seem to be sided! Now: 2010 2.4 TDCi 110 Utility Wagon
Post #431533 17th Jun 2015 3:50am
Quick question, I notice Genuine springs have coloured markers painted on them.
I'm assuming this is to signify the difference between HD, 110 & 90 /. 130 and front and rear etc.
Doesn't anyone knock which is which and part numbers?
I only ever light tow and don't like the idea of HD springs as I know they give a rough ride 90% of the time unless your carrying weight.
*edit* Apologies, appears to be listed above on the second page of this thread. Embarassed
Post #441883 31st Jul 2015 10:02am
Page 2 of 3 <123>
