Home > Technical > Battery charging on vehicle |
it's a trickle charger .... don't worry
4th Dec 2013 12:39pm |
Oh right, I take it that the C Tek is not like my old chargers that bang the charge in as fast as the battery will take it. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to us off. Richard |
4th Dec 2013 1:16pm |
my c-tec is designed to stay connected to the vehicle for long periods ... check the documentation on the web site or instructions but as far as i know that's what c-tecs are for, for the model I have it states the chargers can be connected for months
have a look here for the manuals http://www.ctek.com/gb/en/page/support/manuals |
4th Dec 2013 1:20pm |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 |
These are a brilliant addition to any trickle charger... Can give a very neat installation and easy connection without lifting up the seat.
http://www.mobilecentre.co.uk/index.php?ma...cts_id=692 http://www.mobilecentre.co.uk/index.php?ma...cts_id=694 Also have the benefit it wont cause any any damage (esp the first one) if you drive off and forget to unplug. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
4th Dec 2013 1:32pm |
they look good Ian, typically where would you fit them on a defender ?
4th Dec 2013 2:33pm |
With an IP rating of 42 connected and 40 disconnected I would say 'under cover' ideally, or inside the vehicle or even in a higher rated enclosure if fitting externally. If you go through life with your head in the sand....all people will see is an ar5e!!
4th Dec 2013 2:51pm |
Ideal for fridges etc in the back of a defender, but for battery charger you can mount to the grill surround or front bumper.
With the optional cover the base is sealed from the elements. http://www.mobilecentre.co.uk/index.php?ma...cts_id=696 You see these plugs fitted to fire engines etc.... so no damage caused if they drive off without disconnecting. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
4th Dec 2013 2:55pm |
As I have already said I have the parts but was concerned about charging the battery while still connected to the vehicle. Don't make old people mad.
4th Dec 2013 3:00pm |
No issues with a proper intelligent charger.
4th Dec 2013 3:06pm |
Is that the machine or the person operating it Don't make old people mad.
4th Dec 2013 3:19pm |
Lol....
Make something idiot proof..... and then you get a better idiot. With a c tek or similar you won't have any issues. I use a the bigger chargers on a daily basis. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
4th Dec 2013 3:28pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
Can also charge via the 12S or 13 pin towing socket
http://www.disco3.co.uk/shop/index.php?act...oductId=45 Non latching plug mod: http://www.disco3.co.uk/wiki/Remove_lock_button_from_CTEK_plug 1988 90 Td5 NAS soft top 2015 D90 XS SW |
4th Dec 2013 3:30pm |
Or an old idiot Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
4th Dec 2013 4:17pm |
Thanks for the replies they have put my mind at rest just got convince SHMBO.
Too dark now but will get round to fitting connector in the next few days. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
4th Dec 2013 4:19pm |
