Home > Technical > Battery charging on vehicle
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
This question may have been asked and answered in the past but after 3 hours searching I am unable to find any record.
I have normally disconnected or removed a vehicle battery to charge it.
I splashed out and bought a C tek charger, for my caravan batteries, along with a comfort charger and panel connector as I thought that I could just connect them upto the land rover battery and switch on to maintain the battery.
Today I have some spare time so I was just about to start the installation when a nagging doubt crept into me mind, " If I connect the panel connector to the battery and then connect the charger what damage will I do the electronic bits of the Land Rover" I have tried to reason with myself that C Tek would not sell the adaptors if it wasn't safe but the doubt will not go away and SHMBO has stopped the job until I can get an answer.
I cannot go through the 12s as this has a relay which only operates in one direction to prevent the vehicle draining the caravan battery.
Is anyone able to help an old duffer with the answer. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #287598 4th Dec 2013 12:16pm
it's a trickle charger .... don't worry
Post #287601 4th Dec 2013 12:39pm
ARC99
Oh right, I take it that the C Tek is not like my old chargers that bang the charge in as fast as the battery will take it. Don't make old people mad.
Richard
Post #287610 4th Dec 2013 1:16pm
my c-tec is designed to stay connected to the vehicle for long periods ... check the documentation on the web site or instructions but as far as i know that's what c-tecs are for, for the model I have it states the chargers can be connected for months
have a look here for the manuals http://www.ctek.com/gb/en/page/support/manuals
Post #287612 4th Dec 2013 1:20pm
Porny
Site Sponsor
These are a brilliant addition to any trickle charger... Can give a very neat installation and easy connection without lifting up the seat.
http://www.mobilecentre.co.uk/index.php?ma...cts_id=692
http://www.mobilecentre.co.uk/index.php?ma...cts_id=694
Also have the benefit it wont cause any any damage (esp the first one) if you drive off and forget to unplug.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #287613 4th Dec 2013 1:32pm
they look good Ian, typically where would you fit them on a defender ?
Post #287622 4th Dec 2013 2:33pm
K9F
With an IP rating of 42 connected and 40 disconnected I would say 'under cover' ideally, or inside the vehicle or even in a higher rated enclosure if fitting externally. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #287628 4th Dec 2013 2:51pm
Porny
Site Sponsor
Ideal for fridges etc in the back of a defender, but for battery charger you can mount to the grill surround or front bumper.
With the optional cover the base is sealed from the elements.
http://www.mobilecentre.co.uk/index.php?ma...cts_id=696
You see these plugs fitted to fire engines etc.... so no damage caused if they drive off without disconnecting.
Ian IRB
Post #287630 4th Dec 2013 2:55pm
ARC99
As I have already said I have the parts but was concerned about charging the battery while still connected to the vehicle. Don't make old people mad.
Richard
Post #287631 4th Dec 2013 3:00pm
Porny
Site Sponsor
No issues with a proper intelligent charger.
Ian IRB
Post #287632 4th Dec 2013 3:06pm
ARC99
Is that the machine or the person operating it Question Don't make old people mad.
Richard
Post #287635 4th Dec 2013 3:19pm
Porny
Site Sponsor
Lol....
Make something idiot proof..... and then you get a better idiot. Wink
With a c tek or similar you won't have any issues. I use a the bigger chargers on a daily basis.
Ian IRB
Post #287636 4th Dec 2013 3:28pm
Martin
Site Admin
Can also charge via the 12S or 13 pin towing socket Whistle
http://www.disco3.co.uk/shop/index.php?act...oductId=45
Non latching plug mod: http://www.disco3.co.uk/wiki/Remove_lock_button_from_CTEK_plug  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #287638 4th Dec 2013 3:30pm
ARC99
Porny wrote:
Lol....
Ian
Or an old idiot Whistle Don't make old people mad.
Richard
Post #287655 4th Dec 2013 4:17pm
ARC99
Thanks for the replies they have put my mind at rest just got convince SHMBO.
Too dark now but will get round to fitting connector in the next few days. Don't make old people mad.
Richard
Post #287656 4th Dec 2013 4:19pm
