Home > Td5 > Refillin R380 gearbox oil
excossack
Currently to fill the R380 I run a bit of pipe under the sill, over the chassis and into the filler and then use gravity to do the job. Is there an easier way ? I was thinking of like a garden sprayer type pump, put the oil in and then pump up the jam (sprayer) and then fill with the pipe.
But, not sure the pipe would be the correct bore to do the job with any speed.
Any other thoughts? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #287416 3rd Dec 2013 8:22pm
ibexman
How about pipe and a funnel from engine bay or a suction pump Thumbs Up
Post #287423 3rd Dec 2013 8:29pm
StephenO
What you've described above is exactly what I use, bought it out of Homebase for about 12 quid. Saves a lot of hassle. Thumbs Up 2007 Defender Puma Tonga Green
2015 Range Rover Sport Autobiography Corrie Grey
1968 Series 2a Bronze Green
1995 Defender 90 Coniston Green
2005 Discovery 3 Zambezi Silver
Post #287428 3rd Dec 2013 8:36pm
I've got a garden sprayer for this very purpose. It's slow but controllable and mess free. I've put a short length of rigid pipe in the end of the flexible tube, which helps it stay in place in the filler hole. Darren
Post #287432 3rd Dec 2013 8:37pm
Phatcat
United Kingdom 2002 Defender 90 Td5 CSW Java Black
I've always used a gear oil pump bought from machine mart for about 15 kwid. Looks like a grease gun with a flexy tube on the end. It's quick, clean and cheap.
Post #287443 3rd Dec 2013 8:40pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
When changing my gearbox oil i feed a piece of plastic pipe from near the brake servo down to the filler hole and insert a funnel into the hose and simply pour the oil int the funnel and let gravity do the rest. 2005 Td5 90 XS
Steve
Post #287488 3rd Dec 2013 9:14pm
excossack
So maybe my idea of the sprayer is a good one... Also good for axles & transfer case 1999 Defender TD5 110
Regards
John M0VAZ
Post #287490 3rd Dec 2013 9:16pm
landy andy
Garden sprayer for me too. Works really well if oil nice and warm.
Andy
Post #287491 3rd Dec 2013 9:19pm
jimbob7
This /\/\/\ £1 fer a meter of 12mm (ish) clear pipe ,another £1 ferra funnel.You can just about see the filler hole from the engine bay. You can just about do the axles with pipe and funnel,it is a bit slow with the oil being so thick. Pov.spec,ftw. 2006, 110,TD5.
Post #287536 3rd Dec 2013 11:27pm
Carlosbeldia
Columbia 2001 Defender 110 Td5 SW Epsom Green
You can use a hand fuel pump for boats, it costs around 10 pounds here in COlombia, you can find it in any boat store. Mine can fill the gearbox with ATF in about 4 minutes. The transfer goes for about 10 minutes....
Post #287548 4th Dec 2013 4:37am
landy andy
"Fill the gearbox with ATF"
Should that not be MTF? Or do you prefer ATF?
Andy
Post #287550 4th Dec 2013 4:43am
Carlosbeldia
I have a problem here with MTF, it's extremely expensive, about 6 times the cost of ATF (Land Rover one is about 10 times more expensive). My gearbox only used it during 20.000 km (bests of his life, I think, it was really smooth those km). Right now the gearbox have 230.000 km and have some issues, it's going to be done a full maintenance on april 2014, so from then I'll start using Honda's MTF (have a new job right now so can afford the extra cost). With MTF I would think this manual fuel pump must be even faster...
Post #287618 4th Dec 2013 2:16pm
geobloke
I am a bit of a fan of the oil safe products http://www.oilsafesystem.com/oss-oil-safe/...s-and-Lids think difflock.com sell them here in the UK. They are not the cheapest, but they work flawlessly. I use the hand pumping version with the hook type end for the R380 filler hole, works a treat.
Post #287854 5th Dec 2013 8:38am
Carlosbeldia
This is the one I have
Post #287895 5th Dec 2013 11:42am
kevb
I have the oilsafe pump too, wasn't cheap but must have had it 10 year s now so its paid for itself. very happy with it.
Post #287953 5th Dec 2013 4:27pm
