Home > Maintenance & Modifications > LR008247 Crash Plate....& "Recovery points"? |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
https://www.defender2.net/gallery/albums/u...008247.pdf
I think the standard eyes could stay. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
23rd Nov 2013 4:18am |
My SVX came directly from Solihull with that very same undershield installed. The original tow points are also in place. I think it is quite logical that the tubular shaped protection which seems standard equipment in Australia will have to be removed though to make place for the undershield.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
23rd Nov 2013 4:34am |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
I've had both the tube and the plate and they are mutually exclusive. They use several of the same mounting holes, and occupy some of the same space.
Pete |
23rd Nov 2013 8:54am |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
those are lashing points, not recovery points anyway. wouldnt trust them myself.
23rd Nov 2013 10:43am |
JR Member Since: 07 Dec 2012 Location: Auchtermuchty Posts: 532 |
I'm with mikeh501 on that one! The Jate Rings are better but they were designed as lashing points for the British Military who needed a bigger eye for their kit.
23rd Nov 2013 12:19pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3778 |
Thank you for all for your replies.
So, bearing in mind that there've been various comments on here regarding the lack of strength of the standard bumper, if our 90 had to be towed, where would the tow rope be attached? Cheers, Pickles. |
23rd Nov 2013 8:48pm |
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 617 |
I bought that steering guard and found that the cutouts for the Jate rings were not as shown in the fitting instructions. I had to get the plate milled to fit.
24th Nov 2013 8:51am |
So as standard you can use these for towing. Absolutely no issues towing on the road with these, especially if you make a bridle and use 2. These are NOT for off road recovery as the force is much higher. Click image to enlarge You can remove the lashing eyes and replace with what are called JATE rings. These can be used for recovery but its still not ideal because of their location. If your stuck, then most likely these will be covered in mud! Click image to enlarge Other cheap option is to fit a set of these over your existing bumper Click image to enlarge Best option is to fit a winch bumper (ARB or similar) which have built in swivel recovery points all nicely positioned and rated. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
24th Nov 2013 8:41pm |
I am aware of the "configuration" of a bridle, but is there a commecial item, or do you have to make it up yourself?
Cheers, Pickles. |
25th Nov 2013 8:25am |
You just buy it separately. A 2m strop or rope with centre wear braid and a couple of bow shackles which fit your recovery points.
25th Nov 2013 6:37pm |
