Home > Td5 > Brake light problems
abiffen90
United Kingdom 1999 Defender 90 Td5 HT Epsom Green
Fitted RDX LED rear lights to my td5. Worked but didnt get brighter when using the brake. Put the originals back on so i could drive it, but now they dont work either? Any ideas?
Post #284393 22nd Nov 2013 7:49pm
roel
fuse? Roel
2003 90 Td5 (2009-now)
Post #284464 23rd Nov 2013 4:10am
Wired them the wrong way round, so the "brake" is coming on with sidelights? so when you press the brake, the (dimmer) sidelights are actually lighting, but you can't see them?
Post #284469 23rd Nov 2013 7:01am
abiffen90
Cheers for you help, ill take a look. Wouldn't i had wired them the wrong way because its a simple clip on off.
Post #284521 23rd Nov 2013 11:54am
jimbob7
I've seen a few posts that state you have to swap the wires round on LED's,sure someone will correct me if I'm wrong. Pov.spec,ftw. 2006, 110,TD5.
Post #284524 23rd Nov 2013 12:04pm
