Home > Td5 > Brake light problems |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
fuse? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
23rd Nov 2013 4:10am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6088 |
Wired them the wrong way round, so the "brake" is coming on with sidelights? so when you press the brake, the (dimmer) sidelights are actually lighting, but you can't see them?
23rd Nov 2013 7:01am |
abiffen90 Member Since: 14 Nov 2013 Location: Gloucestershire Posts: 17 |
Cheers for you help, ill take a look. Wouldn't i had wired them the wrong way because its a simple clip on off.
23rd Nov 2013 11:54am |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
I've seen a few posts that state you have to swap the wires round on LED's,sure someone will correct me if I'm wrong. Pov.spec,ftw. 2006, 110,TD5.
23rd Nov 2013 12:04pm |
