![]() | Home > Puma (Tdci) > Drawbar pull |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
Drawback pull is probably the least useful statistic you can quote for any kind of vehicle since it has no practical meaning!
As far as I know all trad Landrovers (Defenders and leafers) have always been rated to tow 3.5 tons on overrun and 4 on coupled brakes, with very few exceptions. Modern ones do it more easily and it can be concluded that they have a greater db pull. |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 ![]() ![]() ![]() |
Towing weights have been done to death on the series 2 club - in a nutshell upto about 1978ish the max was 2 tons, then they were upgraded to 3.5 (4t with coupled brakes) and have remained so ever since. Check out a series IIA or III owners handbook for the figures. Nobody knows why there was the upgrade as there was little change in the specs... 2011 110 USW
1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
landybehr Member Since: 17 Apr 2013 Location: -D- Posts: 173 ![]() |
Does that figure relate to the load on the drawbar when pulling (instead of the payload)? The trailer may weigh 3.5to, but it needs much less of that to move it forward. But I could have missed the point, wouldn´t be the first time. ![]() |
