Home > For Sale & Wanted > FS Double Din Fascias
Page 2 of 3 <123>
just did a quick google ... saw one in a london car audio e-shop for £265
(looks like you need to cut the vent off the top of the moulding and re-attach to modified fascia)
Post #284188 22nd Nov 2013 8:43am
leeds
If you search the internet you will always find a range of prices /currencies/carriage/VAT for any item.
It is always important to compare like with like, is it the exact same item with exact same specification?
Is it legal in the UK? Will you be liable to custom duties/VAT if bringing in from abroad
Is UK VAT included in the price, many UK webshops add UK VAT at 20% at checkout so on first sight appears cheaper to those that include VAT in the price.
Over last year headline exchange rate Euro to GBP has varied from 1.14 to 1.24 euros and today the £ has hit a 9 month high against the Euro.
Brendan
Post #284227 22nd Nov 2013 11:05am
Last time i looked on a map, London was in the UK Thumbs Up
Double din fascias don't need 'E' marking Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
Post #284233 22nd Nov 2013 11:12am
SteveG
2005 Defender 90 Td5 CSW Belize Green
GEllis wrote:
thanks for the links, I have tracked down different suppliers for the double din, however they all do the side panel which holds the switches with a circle for a clock or boost gauge. I just wanted the panel to contain the switches, probably seems a bit fussy but I just prefer the look. Guess I'll have to put up with a blank circle or another clock.
There looks to be enough plastic between circular cut and rest of switches to cut off. Then file edges to same radius, bevel edges, repaint and should look good. Smile
So when you do all of that and there's still £100 difference (+33%) in the price what would you do?? Wink Wink
Post #284238 22nd Nov 2013 11:29am
Merlin
I see that In Car Music have a double DIN kit with brackets to hold the tuner unit securely. I have asked them if they would sell the brackets separately, but they won't even though they buy the kit in from a wholesale supplier. See:
http://www.incarmusic.co.uk/fitting-access...panel.html
As I'd like to put brackets on my one, does anyone know who supplies these brackets?
Merlin
PS as far as I can see, only ICM use brackets, am I worrying unduly?
Post #285081 25th Nov 2013 1:13pm
leeds
Black Friday weekend offer HERE
Brendan
Post #286600 30th Nov 2013 6:58pm
thatsilverpuma
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
I've been keen to get a double din fascia for a while now, but my defender doesn't have that...um...headlamp dial??
Could someone please tell me what that dial to the left of the 3 bottom buttons is?
Also are there double din fascias without the holes for that dial?
What is the best option for someone in this predicament?
Thanks
Post #536197 31st May 2016 4:26pm
Grenadier
That is the headlight level adjuster switch. Easiest option would be to get a standard double din dash, as they'll all come with that hole, and then either put a blanking plate in or merely buy a switch and pop it in, even if it doesn't work.
 Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #536235 31st May 2016 6:39pm
siglo
Kuwait 2015 Defender 90 Puma 2.2 SW Corris Grey
are these double DIN's still available?
Post #567349 28th Sep 2016 3:39pm
JOW240725
These specific ones from Busdriver aren't (see earlier in thread) but you can get double din fascia's from various other suppliers see Brendan as one. Thumbs Up James
Instagram @suffolk_rovers
Post #567356 28th Sep 2016 4:02pm
siglo
@JOW240725
Thanks, I have seen those. I am looking for the type that comes with its own vents instead of cutting the stock fascia vents off.
Post #567413 28th Sep 2016 7:07pm
JOW240725
I know what you mean, I was dissapointed to hear these weren't available also. The double din fascia cost a fortune especially when you still have to cut the original vents off!!
Twisted is the only one I know with the vents complete, but costs!!! http://twistedautomotive.com/store/double-din-panel/
Thumbs Up James
Post #567420 28th Sep 2016 7:41pm
siglo
@JOW240725
I was hoping to find another source beside Twisted Confused
Post #567430 28th Sep 2016 7:57pm
thatsilverpuma
Hi guys, thanks for the advice a few months back, I eventually found a site that was selling double dins for a reasonable price, £184.95 Exc VAT, unfortunately they're the kind that don't have the vents at the top but I figured I can always buy a stock fascia in future if need be. I'll link the online store (SP 4x4) below. Really great service.
As for the side panel and cutting into the dash, I didn't really need it, I had quite a few unused buttons on the stock fascia so the reduction in button holes on the double din fascia wasn't a problem. I did some digging and turns out the Disco 2 hazard button is the exact same type as the Defenders small buttons. So I'll be using one of them as my hazard switch instead of the stock large hazard button.
The headlight adjustment switch holes weren't an issue either, the blanking plate on the stock fascia comes out really easily and just clips into the new fascia. (For any SA and Aus owners)
I've also ordered an Android double din radio that's supposedly being delivered this Tuesday so I'll keep you guys posted, hopefully I wont run into any problems. It also comes with an OBD2 dongle, which should be quite nice.
The fascia I bought is of really great quality if any one was wondering, tough good quality plastic, went for the matt black option, its probably better quality than the original!
http://www.sp-4x4.com/Land_Rover_Defender_...202713.htm
Post #568052 1st Oct 2016 6:47pm
Mac22
United Kingdom 2013 Defender 110 Puma 2.2 DCPU Santorini Black
Watching.... Thumbs Up
Post #568061 1st Oct 2016 7:15pm
Page 2 of 3 <123>
