Home > For Sale & Wanted > FS Double Din Fascias
Page 3 of 3 <123
Stiff1
That really is a great price.
As a note, I also used the Disco 2 switch on mine, be aware it will not work on the existing plug/ loom.
I had a new one made up and also an extra LED fitted and rigged to flash when the Hazards are on.
Post #568278 2nd Oct 2016 7:33pm
thatsilverpuma
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
Oh really, thanks for the advise, I knew I'd have to make changes for it to work, just haven't got behind the fascia yet.
When you say "made up", what all was involved? Thanks.
Post #568286 2nd Oct 2016 7:41pm
Stiff1
This is pasted from some of the communications I had.
STOP - DON'T CUT OFF ANY CONNECTORS
Modified switch (on its own, without the Black connector)
The plug-in relay harness - This would plug-in to the existing hazard switch connector, with 9 x 0.5m length cables to the 3 x relays on mountable relay bases, and 4 x 0.5m length cables from the relays to a Black 5-way switch connector to plug-in to the D2 hazard switch.
3 x automotive relays.
This works-out slightly cheaper than using a single 4PCO relay & base - but, the wiring is a little more complicated.
It also takes up a little more room - but, is easier to mount in a vehicle.
I also had the switch dismantled and the second red LED added so the flash could be achieved (see here http://www.defender2.net/forum/topic42402-15.html )
Paul Mc on here is the man if you want it done.
Hope this helps.
Post #568317 2nd Oct 2016 9:31pm
thatsilverpuma
Wow this sounds a little more complicated than what I expected.
I'm not that clued up on the electronics of these Pumas.
How much did this whole process set you back if I may ask?
I'm really battling to understand those posts but that may be due to lack of understanding, did you require an extra switch behind the dash or am I understanding wrong?
Thanks for the advice!
Post #568428 3rd Oct 2016 3:38pm
Page 3 of 3 <123
