Home > In Car Electronics > Crossovers |
jimsadventure Member Since: 10 Nov 2013 Location: edinburgh Posts: 199 |
Right ,, got a set of focal speakers , comes with fronts as per defender spec size , rears are bigger than standard but have modified pods to fit .. Tweeters are in ,, now for the crossovers , never fitted a set of these , are they straight forward and do I really need them ?? , will they make any difference to the end result ,, where have you guys fitted the crossovers in the truck ??
21st Nov 2013 5:55pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2651 |
i double sided sticky taped it to the side of the dash... space is right in there, and the difference is huge. focals are well worth the price. just wish i could figure a decent sub to match them
21st Nov 2013 5:58pm |
Thanks for that , will check it out in the morning , next question is , have a clarion head unit DVD sat nav thingy , I want this in the svx but it doesn't work with the sub that's built into the cubby box , I get the unit to work itself but no bass unit , Ido I need a different connection ??
21st Nov 2013 6:49pm |
Baldinho Member Since: 28 Oct 2012 Location: Surrey Posts: 123 |
Customsteve will be along shortly no doubt, he's v helpful. I'm doing the same as you on Saturday with the Focals, found a vey good photo on this link on how to do crossovers:
http://www.defender2.net/forum/topic18027....p;start=30 |
21st Nov 2013 7:33pm |
Cheers for the link fella , think i have it now , if i get stuck i will let ya know |
21st Nov 2013 10:54pm |
Thanks for the input bud ,, my crossovers are adjustable , will be trial and error i guess to set them up for best sound results but im open to as much advice on this subject as poss .. As for the sub/amp in the svx ,, there are two block looking connectors at the back of the HU,, my new clarion plug will go into one of them , but no sound from it , the bass unit that is , the new HU has amp cables on the back , do i plug the amp cables that are there into the cables from the new HU, the amp cables in the dash plugged into the back of the standard unit , there was no cables on this unit , just plugged into HU.. Give me an engine to strip anyday than try to sort out stereos .. Sorry if this sounds confusing ,, its bloody confusing me |
21st Nov 2013 11:08pm |
